Michelin Cup 2 R K1 (Ferrari Spec) on GT3?
I ran a search and couldn't find anything on this so forgive me if it's been discussed already
I was looking at Tirerack to get a new set of Cup 2's for my 991.2 GT3 and noticed the Ferrari spec K1 Cup 2 R are the same size as our N1s. I'm looking for more grip and the Rs are obviously amazing tires, I'm just concerned about running non OEM tire on the car. Is there a downside to running these, both from the perspective of its a Ferrari spec vs Porsche spec and that the R wasn't designed for stock non-RS GT3?
Would be particularly helpful if someone whose run this setup chimes in
GT2Driver (06-09-2020)
As long as the tire is developed to compete against each other.
If the tire fits on the wheel you are running, you are good to go. All this ' N spec' stuff is marketing. Each tire will perform differently per driver, car, track, ambient temp etc....Some will say Trofeo R's are sticker than Cup 2's but fall off faster in grip with less heat cycles etc....some will say the other way for Cup 2's. Tire choice is very personal.
Porsche N-Spec 305s are almost same size as 325s with regular spec.
The following 3 users liked this post by hellboy_mcqueen:
Sidewalls are different.
Basic Sponsor
WE'RE NO LONGER ACTIVE ON THE RENNLIST FORUMS - FOR ALL ENQUIRIES PLEASE CONTACT US VIA THE JCR WEBSITE BELOW
/ / / JCR PORSCHE \ \ \
contact@jcr-developments.com
Facebook | Instagram | Youtube
DK7 (06-10-2020)
You have to look at the weight rating - Porsche have light front ends and heavy rear ends.
Basic Sponsor
Pista Cup2 R with K rating is the same construction as the GT3 sized Cup2 connect (245/35/20) (305/30/20)
Ferrari actually had no technical input into the tyres construction, this is a marketing spin. Car manufacturers make the cars, tyre manufactures make the tyres and unless it's a very specific and unusual application, think Veyron and Chiron then the manufactures simply develop and refine the chassis and handling characteristics around the tyre that's suggested to them. Koenigsegg are a prime example of this.
It's a common misconception driven mostly by tyre markings that its the tyre manufactures designing their tyres around the car. Kind of in the same way that you wouldn't imagine Tennis ball manufactures develop the ***** to suit the companies that produce the rackets![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
JC
JC
