New BAT GT3-engine trim needed
Originally Posted by Alan C.
If an owner had the bumper cover off for an exhaust or filter service some of the hardware may have been misplaced. Rather than making a trip to the dealer for the appropriate parts the owner may have just sourced 'if it fits it works' hardware from his local hardware store. Wouldn't be the first time I've seen this behavior.
Is the wire loom going from the car to the lid correct? It looks off in the pic to me, but I don't have a GT3 to compare against. On my RS it has an accordion looking rubber loom covering the wires.
I was watching the action, I feel you got a great deal on a great car!!
That being said, for this price, they should have fixed the trim before the auction. Yeah, it's very easy to loose the bolts and trim pieces. The bumper has to come off for just about any service. I have taken mine off a few times now and I just keep all the parts in a magnetic tray. That being said, you don't have to remove the upper side trim pieces, and the trim on the top of the rear bumper vent also does not come off. That part is a bit weird.
What I see....
You need the 2 wings on either side of the fan.
2 new tail light bolts (wonder if the black bolts come from another place and are now missing?)
2 black plastic covers *(these go over the black bolts once replaced)
1 upper trim over the bumper vent.
Have fun with the car!!
What I see....
nice color and good buy
enjoy in good health!
Originally Posted by stephen k
Could be that the dealer did serviced the engine filters which are behind the bumper and did a very unsatisfactory job putting it back together..
again, the parts that are broken/missing/wrong should not be removed to do any service. rear cover comes off by removing the tail lights (two silver screws) then a bunch of screws around the perimiter. the trim between the grill and the carbon piece does not get removed. the carbon piece does not get removed. the small plastic cover on the right of the engine bay does not need to come out and you don't need to pull on the plastic cover by the oil cap hard enough to break it because it does not need to come off. of the dealer lost all the parts during the service i would wonder about the quality of the service. i find it bizarre that all these parts are missing or have been replaced because it implies an accident or a very unskilled person working on the car. either way not good. whether the car is mechanically and/or structurally sound cannot be determined from the pic. i would investigate if I were the OP.
They would have gotten away with it if it wasn’t for those pesky trim pieces too. Rats!
Originally Posted by itrsteve
So what you’re saying is that the safest assumption here is that the car was crumpled into bits, likely on fire then nearly flawlessly rebuilt had they not forgot the final (and cheapest) piece.
Hopefully it was just a careless tech that didn't know what he's doing when taking the rear bumper off for air filter change, ecu change, exhaust work (actually you don't need to pull bumper to change either the center or side mufflers), etc. Don't sweat too much OP, get trim pieces on both side and start enjoying the car.
Great eye! The OEM hinges are body colored along with the screws. Something happened to change out the hinges, they come like this as replacements. The hinges have in fact been replaced.
How do I know that? Well there is another thread where the newer cars come with carbon fiber hinges and lo longer have the gas struts. I ordered a set, and they sent me the original hinges, that look just like these.
Perimeter (04-25-2020)
