Torque for tightening wing nuts on GT3 RS
I've been driving my 2016 991.1 GT3 RS around the tracks regularly, and after this last track event, I noticed that the driver's side rear nuts that hold the wing stable are loose, which allow the wing to rattle up and down a bit. I realize that I need 2 T27 torx wrenches to tighten these nuts. Does anyone know if there's a recommended amount of torque to tighten these nuts that hold the wing in place? Thanks.
9.7Nm or in olde worlde 7.2ftlb
Thanks. I just tightened estimated a 7-14 ft lbs torque using two ratchets (tight, but not so tight that I stripped the threads). I also was able to use one T27 and one T30 to tighten the nuts, (instead of two T27), as both would fit in and hold the nuts during the tightening process.
The shop manual says Fastening Tightening 9.7 Nm (7.5 screws for torque ftlb.) upper part of
rear spoiler
rear spoiler
Yes, I noticed when tightening the nuts on the wing that the T30 fit more snugly in the nut than the T27, as I ended up using both T27 and T30, since I didn't have two T27's. (That first comment of mine about using the T27 was simply from reading other posts here on Rennlist about adjusting the wing in the RS: I read about half a dozen posts and they all said to use a T27 when adjusting the wing nut, which appears to work, but probably isn't the best fit.)
Thanks for your comment.
