991 GT3, GT3RS, GT2RS and 911R 2012-2019
Another oil tank failure
Old 10-16-2019, 02:54 PM
Marto
Marto's Avatar
Default Another oil tank failure
Second failed oil tank on 991.2 GT3. Last one replaced under warranty last year, 2 months off the road. Exactly the same failure this time - a pinhole through a spot weld, exactly the same spot weld. Will post photos once received...
Old 10-16-2019, 02:59 PM
bli8
bli8's Avatar
Can you patch the leak with something so car can still be driven while waiting for part/service?
Old 10-16-2019, 03:05 PM
Marto
Marto's Avatar
Engine had to come out to confirm the location of the leak.
Part was ordered and arrived after about 10 days this time. Unfortunately, it is the identical part so my dealership are discussing with Porsche the possibility of a modification since there were identical pin holes in both tanks.
Old 10-17-2019, 12:47 PM
n2cars
n2cars's Avatar
Where under the car would you notice the leak? Left, middle, right?
Old 10-17-2019, 12:57 PM
GrantG
GrantG's Avatar
Received 5,171 Likes on 2,916 Posts
Tank is on the right side (closer to front of undertray). You can take a cell phone pic of the undertray just below the tank (to see if it's dry) without removing the tray or jacking the car (just behind the right rear tire).
Here's an example (not the best pic, but it's dry underneath, if a bit dirty...). You can see the welded seem on the right curving up:
The following 3 users liked this post by GrantG:
fjpdds (10-18-2019), Palting (10-15-2022), s4corrado996tt (10-18-2019)
Old 10-17-2019, 01:18 PM
HenryPcar
HenryPcar's Avatar
bump
Old 10-17-2019, 01:24 PM
n2cars
n2cars's Avatar
Thank you. I guess I have a different problem. Had the first oil change on Tuesday and now have this large oil stain today.
Old 10-17-2019, 01:40 PM
GrantG
GrantG's Avatar
A drip in that area could be from the mechanic filling in the new oil too fast - it is easy to do this and have some overflow in that area. If this is what happened, that should improve on its own in a short time...
You could also jack the rear of the car and have a look and see if it's wet - might be able to dry it with a rag, as it's best not to have oil on the exhaust there.
Old 10-17-2019, 01:47 PM
Marto
Marto's Avatar
Exactly, the oil tank is on the right hand side looking from the rear - though the oil had spread around somewhat by the time I noticed a drip on the floor, the drip was also on the right hand side.
Old 10-17-2019, 01:50 PM
n2cars
n2cars's Avatar
thanks Grant
Old 10-17-2019, 04:41 PM
n2cars
n2cars's Avatar
-Grant
Grant, you were right on. Just got back from the dealer and the problem was exactly what you described. Thanks again
Old 10-17-2019, 04:43 PM
GrantG
GrantG's Avatar
-Grant
Glad it was an easy fix
Old 10-18-2019, 03:53 AM
s4corrado996tt
s4corrado996tt's Avatar
Subscribed!
Old 10-18-2019, 10:52 AM
Christian Plyler
Christian Plyler's Avatar
Seems like you could just run a TIG arc slowly along the bottom of that seam, and probably fix the pinhole.
Old 10-19-2019, 01:56 PM
Marto
Marto's Avatar
The hole isn't on the seam, it's on the face of the tank, near the top. I'm away from home at the moment but will try to get pictures from the dealer.
Quick Reply: Another oil tank failure
