GT3 owners with no front lift, how bad is it?
#46
https://youtu.be/OnkREgIPWN0
Front lift saves me all the time look how close i get fully raised... Just sayin.
That being said, there have been some inclines or small ramps in parking lots that I just couldn't take in the GT4, period, because the path was too narrow to get the right angle. I had to back out of a few hairy/embarrassing situations. My question for the people who said they didn't need FAL in SF or LA, do you go everywhere? Like strip malls with good hole in the wall restaurants, or small motels on a hill in Monterey that have weird parking lots before a track day?
#47
I literally just watched a owner of a GT3 (Video above), reverse directly straight out of a driveway, in a front axle lift thread..... hahahaha
My F80 M3 is lower than anything and I've gotten out of the steepest driveways.
I come from an era of driving slammed race cars on the streets, so learning how to crawl out of a driveway is imperative.
FAL isn't a necessity, but a convenience. It shouldn't deter you from buying a car without it. I have seen a couple of 997 GT3's with the FAL broken and needed to be fixed. Lot more pricier of a replacement Cup lip.
Bossing (09-17-2019)
#48
no need. just be careful. and like others have said its replaceable and unless you really plow something hard like a parking stop thing then i have no idea how you would damage the actual bumper...
i think you said .1 but on my point 2 i have noticed in addition on steep inclines where the front scrapes, the rear diffuser fins scrape as well.
if its the perfect car for you, buy it.
catdog2 (08-07-2022)
#51
This is almost like a manual vs. PDK topic.
Listen man. I live in L. A.
I use it All the time. I think I was being conservative in the last thread. I probably use it at least 18-20 times per day in L. A. , O. C.
But here's the thing. If I found the perfect car, I would buy it. Don't take a pass because it doesn't have it.
Just take more time with your entry and exit and stock pile a couple extra front lips in your garage.
I'm on my 2nd front lip and I'm super careful.
Just don't let a car pass you by that doesn't have it if everything else the car is optioned with is what you want.
#53
I would be worried more about the bumper flex as the lip just passes forces on to the bodywork. Especially if I had a PTS car where bumper flex could crack paint. Los Angeles has terrible roads.
Not sure where you are getting $200 from, but everywhere I look they are over $400 for OEM shipped
https://www.suncoastparts.com/product/SKU992GT3LIP.html
BTW, The FAL system on 997.2 was prone to failures which is why Porsche changed design and the 991.2 is far more reliable
#54
#55
I did not get it nor would I now after scraping the bottom of my painted front lip. I was going to my Indy's shop and missed their driveway in the industrial complex they reside in so I did a quick u-turn in another drive, which did not look that steep. I wound up scraping it, like bottoming out kinda, on the way in and I never would have used the FAL if I had it. When I got home I used Black Gorilla tape along the entire edge, back to the wheel openngs, to prevent further damage albeit I should have done that to begin with. Two layers of tape would have been best and I could have peeled one off, just as racers with windscreen film do.
#56
#58
True, but it was an option I could have ordered and the point is the same - they are not that much lower relatively speaking and most would scrape a GT3 or GTS if they did not take their time, angle approaches, etc.
#60
I would rather not have the front lift and replace $200 front lips rather than have it and have to replace the components of it eventually. If you are just keeping the car for a couple years though, get the lift, it will help you especially around a place like LA. Not sure I would have that option make or break a purchase.
