991.1 GT3RS jack points without JackPoints
Recently I saw Archie Hamilton’s car lifted and it seemed to be supported on the crossmember between the lower control arms with jack stands. I wanted to see if that was a safe point to lift or one to avoid?
What I really want to do is get a jack stand on each jack point for wheel swaps, brake pad/rotor changes etc. Jack Points seem a little cumbersome with the plates meeting the open base. My plan: Floor jack the rear jack point first. Place a jack stand on the front jack point. Repeat for the opposite side. Then while i have a floor jack lifting the rear jack point, use my second jack to lift the crossmember and replace my primary jack on the rear jack point with a stand to have 4 jack stands on each jack point. Phew 😅
This sound right?
Stands on crossmember safe?
This sound right?
I also noticed you have yellow calipers. Are you still running ceramics or have you switched out to iron? I’ve had this car for a year and racked up 1000 track miles, 5000 road miles on my original PCCB pads and rotors and im still at 9mm front and 8mm rear pad life and 90+ on the rotors. I have about 6/32 left on my original N1 SC2. I drive mostly my local tracks and did 250 miles at COTA. Surprisingly these 3rd gen PCCB are more durable than the older gen. I’m thinking abt switching to Girodiscs so I can run more aggressive pads hence the jack and jack stand questions. Thanks for your insight.
The JackPoints take a little time to get used to setting them up. After a few tries it becomes easier. I like mine.
Carlos Moro (06-28-2020)
That is where I have been putting my jack stands. There is really no other place. If you are doing a oil change, the stands get in the way of the oil drain pan.
Since the JackPoint stands are on backorder, I just ordered these to make it much easer to get the car up in the air, and give me the entire underside to roll around on.
https://safejacks.com/collections/rennstand
