Sapphire blue bikini / Removal (of fender)
Now that I have your attention...
Can someone help with 991.1 GT3 front fender removal?
I am 95% there, except for 3 nuts. These are inside the door jam and a 9mm socket fits on them. However, when I attempt to loosen them, they just turn. I cannot access the bolt side on the inner aspect of the fender. The washer reservoir is obscuring access. Are these screws or a rivet of some sort? Thoughts?
Three nuts are inside door jam
top two 9mm nuts
bottom 9mm nut
Replacement cup fender, end view
Some massage oil would work wonders.
Aha, massage oil! Now we're talking!
After removing the wheel well liner, the washer reservoir is housed in the left front fender. I cannot see how to remove it.
I Personally don't know but might suggest going into a Porsche dealer and asking the service guys. Even if they don't know they have the full car on computers and that should tell them how to remove the front fender. I've done this once before and they were super helpful. However, they wouldn't let me download a copy of the program!!
sorry can't help on the car, . . .but can try to help everyone else, and request more pics of blue bikini girl
https://rennlist.com/forums/991/1066...ce-manual.html
SJW, a Carin' kinda guy
Thanks, I didn't see that thread. Here's the link
Thanks Evilfij and Todd B,
You guys are the best!
I found my answer. I do in fact have to remove washer reservoir in order to remove wing/fender.
1. Disconnect the battery.
2. Remove front wheel housing liner. → Removing Front Wheel Housing Liner
3. Remove front apron. → Removing Front Apron
4. Remove headlight. → Removing Main Headlights
5. Remove headlight mounting. → Removing Headlight Mounting
6. Remove airbag sensor. → Removing Airbag Sensor Information
Only when removing the right wing:
7. Remove filler flap. → Removing Filler Flap Information
8. Remove desiccator. → Removing Desiccator Information
Only when removing the left wing.:
9. Remove windscreen-washer reservoir. → Removing Reservoir For Windshield Washer System
