991 GT3, GT3RS, GT2RS and 911R 2012-2019
Does the sport button on a GT3 change the cooling settings like on a GT4?
Old 02-27-2018, 08:04 AM
LexVan
LexVan's Avatar
Received 5,402 Likes on 2,513 Posts
Originally Posted by 96redLT4
Hitting the Sport/Sport Plus on my 991.1 GTS does lower operating temp from 220+ to 194. Read somewhere it does this by opening a valve to the third radiator.
Jim
Has nothing to do with the 3rd radiator, because even cars without run cooler oil temps in Sport Plus.
Old 02-27-2018, 08:22 AM
subshooter
subshooter's Avatar
Received 2,218 Likes on 1,014 Posts
Originally Posted by Jimmy-D
Hitting the Sport button on the .2 does not expedite cooling like it does on the GT4
Sure it does. I run around in sport mode in my .2 at it lowers the operating oil temp to 194 just like the 991.1 and 981s.
Originally Posted by LexVan
Only Sport Plus. Not Sport.
That is not true. Go try it when you get your 991.1 out of storage. Sport mode also lowers the car's operating oil temp. Just like in the 991.2.
Of course, I think the 3 of us are referencing the Carrera engine. The OP's original question on the GT3 was already answered.
Old 02-27-2018, 12:30 PM
fxz
fxz's Avatar
Location: The way to hell is paved by good intentions “Wenn ich Purist höre...entsichere ich meinen Browning” "Myths are fuel for marketing (and nowadays for flippers too,,,)" time to time is not sufficient to be a saint, you must be also an Hero
Originally Posted by Bardman
i will make sure to post up pics of sport button on with my sofas in the background when I get my car.
for sensitive butt road might be felt either through sofas
mine is dumb
Old 02-27-2018, 02:01 PM
Jimmy-D
Jimmy-D's Avatar
Received 1,450 Likes on 754 Posts
I am talking about the .2 GT3. I had it out yesterday and did not see any drop in temp in sport mode
Old 02-27-2018, 02:06 PM
zedcat
zedcat's Avatar
Does anyone have the Technik Introduction document for the 991.2 GT3 yet? For the GT4, it describes the map controlled thermostat with diagram. The 991.1 GT3 document does not indicate a map controlled thermostat. Most likely the .2 GT3 is the same.
Old 02-27-2018, 03:18 PM
GrantG
GrantG's Avatar
Received 4,941 Likes on 2,799 Posts
Sport button definitely affects water temp when warming up in GT4, but don’t think it does in GT3...
Old 02-27-2018, 03:28 PM
Jimmy-D
Jimmy-D's Avatar
Does not in GT3 and never did from y understanding.
For the GT4- the 3rd radiator was added to aid cooling hence, why the front end was changed on the Cayman for the GT4. It is either activated by pressing the Sport button or driving it hard which would activate it.
Old 02-27-2018, 04:42 PM
zedcat
zedcat's Avatar
GT4 center radiator is always "active", the thermostat map varies between sport and normal modes or driving style.
Old 02-27-2018, 05:33 PM
Todd B
Todd B's Avatar
Same goes for the other Cayman's. The center radiator just sits in a series circuit between the two front radiators. There's no valve to control flow.
Old 02-27-2018, 05:39 PM
gigi02
gigi02's Avatar
On standard Carrera's the sport button affects oil temperature for fuel economy reasons. This is well documented in the owners manual for all Carreras. With a warmer oil say 102-105 °C the friction in the engine is lower. Primarily useful for the sailing mode in PDK equipped cars. When you push the sport button, engine oil temperature is brought down to circa 95°C which seals the motor better. A better sealed engine outputs more power and is a desired configuration for racing. For those of you who have recent Carrera's you will note that the sailing fonction is disabled when you are in Sport mode.
The .2 GT3 could not care less about fuel economy and the sport button does not have any effect on oil temp. In fact .2 GT3 engines run at a lower temperature than the standard 991's at approx. at 90-92°C under normal usage.
Old 02-27-2018, 07:30 PM
Psup4s
Psup4s's Avatar
are .1s gt3 known for having thermostat issue? Also, I heard of .2 having cooling problems due to faulty coolant lines
Old 02-27-2018, 08:07 PM
Riz
Riz's Avatar
GT4 is not a real GT car. The GT3 is the real deal.
Old 02-27-2018, 08:17 PM
subshooter
subshooter's Avatar
Yawn. SMH.
Old 02-27-2018, 08:30 PM
neurotic
neurotic's Avatar
Old 02-27-2018, 09:20 PM
Nacelle
Nacelle's Avatar
Originally Posted by fxz
GT3 assumes to be butt sport driven
please no button
no sofas
Damn... I guess I can't drive mine butt sport driven, really now.
Quick Reply: Does the sport button on a GT3 change the cooling settings like on a GT4?
