991 GT3, GT3RS, GT2RS and 911R 2012-2019
Gear shifter flexing under torque in 4th gear, on 991.2 GT3
Old 02-05-2018, 06:52 PM
mqandil
mqandil's Avatar
Default Gear shifter flexing under torque in 4th gear, on 991.2 GT3
Hi Guys. I have been enjoying adding some miles on my 991.2 GT3 with manual transmission. Car has been amazing, but I did notice that when I shift into 4th gear and apply any amount of throttle the gear shifter moves forward about 3/16” but does not pop out of gear. I don’t have to step hard on the gas to initiate this movement. I tried 1,2,3,5 6 and the shifter is rock solid with no flexing or movement regardless how hard I accelerate, but 4th is a different story and any slightly acceleration will result in movement. Aside from this the car drives normal and great.
Not sure if this is only in my car, and would like to hear if other experienced the same thing or is this isolated to my car. Usually if the shifter moves, that is usually an indication of bad motor mount but it should happen in all gears and not just 1. I reported the issue to Sunset and I am taking it tomorrow to service so they can inspect the car. Thought I should share this and see if anyone else experienced the same thing. Mark
Old 02-05-2018, 07:07 PM
Jimmy-D
Jimmy-D's Avatar
Received 1,465 Likes on 764 Posts
I have only felt some vibration in the Shifter some times when under acceleration. It may move/bounce a little but not necessarily isolated to one specific gear
Old 02-05-2018, 10:40 PM
sechsgang
sechsgang's Avatar
Received 1,028 Likes on 480 Posts
911r does it in every gear when you go on and off the gas...
Old 02-05-2018, 11:08 PM
Raghu
Raghu's Avatar
My Miata MX-5 does that in every gear. When my GT3 MT comes in at the end of March I can compare the differences and report back.
Old 02-05-2018, 11:35 PM
mqandil
mqandil's Avatar
Thanks. Yeah, some vibration is normal.
Mine only does it in 4th and it is very notciable. I own 16 Spyder, and GT4 and 991.2 Targa 4S and all manual and none of them does this. Let’s see what Porsche service says. Mark
Old 02-05-2018, 11:37 PM
mqandil
mqandil's Avatar
Really.... that is surprising. None of my other manual cars like GT4, 981 Spyder and 991.2 Targa 4S does this and also this one only does it in 4th. This can’t be normal. Hopefully Porsche service will have an explanation.
Old 02-05-2018, 11:41 PM
mqandil
mqandil's Avatar
i have owned many manual cars over the years and yeah some of them did that under hard acceleration but i have not experienced this in any late model Porsches including the 3 other manual Porsches I currently own, hence the question and surprise. Will report back after Porsche service takes a look. Thanks bud and congratulations in advance on your GT3. You are going to love the beast. Mark
Old 02-05-2018, 11:43 PM
Raghu
Raghu's Avatar
Default Thanks Mark
Originally Posted by mqandil
i have owned many manual cars over the years and yeah some of them did that under hard acceleration but i have not experienced this in any late model Porsches including the 3 other manual Porsches I currently own, hence the question and surprise. Will report back after Porsche service takes a look. Thanks bud and congratulations in advance on your GT3. You are going to love the beat. Mark
Thanks Mark.
Please keep us posted on what you find at the service department.
Old 02-06-2018, 03:15 PM
scooteria681
scooteria681's Avatar
i have experienced a maybe somewhat similar vibration/ shifter push while in fourth gear while on the throttle. I wasn’t anywhere close to wide open, rather maybe 50% at most and everything was plenty warmed up. I’ve only had it up to 4K rpm but noticed it only in fourth. Unfortunately, my car has been in the garage since the day after delivery because of cold and crappy weather here so I didn’t get to really check it out or investigate too much. Would love to hear what you find out. I figured it might just be a break in sort of thing, but regardless, haven’t been able to do anything about it here anyway until it warms up some. Like you said, otherwise, car seems great with my limited +/- 100 miles.
Old 02-06-2018, 03:26 PM
Todd B
Todd B's Avatar
On my 997.2 GT3 shifting into 3rd would be a problem when coming out of a corner under heavy acceleration. Similar to my 993 (solid motor mounts on that helped a lot). Always just figured it's the way it is with the engine/transmission layout.
Old 02-06-2018, 03:42 PM
GrantG
GrantG's Avatar
Received 5,127 Likes on 2,888 Posts
I think this is pretty normal to have some movement of the drivetrain with on/off throttle application, resulting in shifter position movement...
Old 02-06-2018, 06:05 PM
Burren
Burren's Avatar
My Hellcat does that sometimes under hard throttle. But, that car has actual torque. My previous Porsches never did what you're describing.
Old 02-06-2018, 06:50 PM
sechsgang
sechsgang's Avatar
My 997 RS did it, so did my 996 gt3...nothing new here...and I doubt anything is wrong.
Old 02-06-2018, 07:07 PM
abiazis
abiazis's Avatar
Check synchro fourth gear if it does pop out......not an easy check.....
Old 02-07-2018, 09:14 PM
Jnosol
Jnosol's Avatar
Your shifter is connected to the tranny, tranny is attached to the motor, motor is attached to the chassis via motor mounts that allow movement under load. What's the issue?
Quick Reply: Gear shifter flexing under torque in 4th gear, on 991.2 GT3
