F&*%ing centerlock's - now appreciate Orthojoe's Avatar
#31
Must be a damn good car to put up with those two huge flaws....
#33
"I don't even have a car yet and I've already got most of the tools. All that's left is something to hold the brake without damaging the seat. Until I have something for that, I'll need a helper."
ToolTopia website......brake pedal depressor. Start engine, depress brake pedal to floor, insert depressor, turn off engine, exit car, work on center locks. OH, and complete "kit" leaves little room for luggage in frunk.
#34
Smart man. I only did it so that I can be somewhat prepared to do a wheel swap or a pad swap at the track during a multi day event......Now I am thinking i might as well just load the car up and head home - I'd miss a entire session trying to swap wheels.....
#35
Will be much easier next time
#36
Check this out, you'll see the little plastic tool and how to use it to jiggle the centerlock spring
https://rennlist.com/forums/991-gt3-...e-by-side.html
#37
Why are you changing your own wheels?
#38
Im glad it worked out, but you have me dreading doing it now for my first time. My last 2 GT3s had the regular 5 lugs on the 996 Manthey GT3 and the 997.1
#39
I think I go through 6-8 sets of rubber gloves in an attempt to minimize where all I get the grease...because I am in the camp which re-greases for each install. PCA had us doing centerlock inspections each morning, loosen, tighten to spec before going out on track.
I have it down to about 15 min, 12 min if I really want grease everywhere and look like the silver surfer.
#41
There is a youtube video But, he leaves out some pretty key points. I feel better now knowing that the locking nut will pop out with some twisting from the small tool (or anything else that will fit in there) as opposed to thinking I had to torque, back off and re-torque over and over to make the magic happen
#42
I live in Arkansas....the nearest tracks to me are 4 to 5 hours away (Barber, Hallett and COTA is even farther). I wanted to make sure I was comfortable, if not proficient, swapping them out in case I need to do so hours away from my local ship during a multi day track event. I dont want to end a two day event just because I can't change wheels and tires......
but if the pads wear out in the middle of an event, I'm packing up!
