"Clubsport" build underway
#47
OK, here is summary of the completed package, hitting the big items that matter. I'll install the BBS wheels with some pics this week, but the alignment is in also. -3.3 front, 0 toe, 9.3 caster. -2.8 rear, .17 deg toe per side.
Ohlins TTX - they are utterly amazing. How the ride can be so controlled, firm, but also not harsh is crazy. It rides virtually no different than stock. The only difference I can feel are the monoball top mounts, and that's a good thing. Track impressions soon, but if they perform this well on the street, they will be equally amazing on track, given their rates are very track focused. Ohlins are 571/1142, compared to 571/913 for the new .2RS. Can reach adjusters on all 4 corners without removing wheels, which is a big bonus.
PASM delete kit - works seamless, no dash lights, no issues. Integrates the suspension seamlessly. Can be used with any aftermarket suspension kit. Super easy install.
Tarett Race Camber plate - Perfect. It allows up to -3.5 deg up front, without any shims, and caster is about 9.3. You can add caster simply by using shims, and not fully decking the camber plate inboard. No caster pucks or arms needed. Better inner strut clearance, and maintain suspension geometry. No downsides. Plus, alignments are faster and easier this way. Makes adjustable solid caster pucks a thing of the past.....
TPC side muffler delete - fantastic. ZERO drone, lets all the factory software and throttle mapping remain as is. You can still hear the valves open as stock. The sound is perfect. Just loud enough to now enjoy it all at RPM, especially in sport mode. Quiet mode is still quiet enough. Flexible upper pipe is a must IMO. I don't like the solid Fabspeed design, there is a reason the OEM setup has a flexible upper section. It's not cheap, but works as advertised, so I'm happy.
GMG LMS rollbar/ Schroth 4pt - looks like factory clubsport package and only weighs 41lbs, which offsets the side muffler delete almost identically. However, it moves the weight inside the rear axle, so handling is still improved. Belts fit perfect, no other mods needed, and feel great. No lap belt in the way is great, with virtually all the same safety. Win-win.
#48
I have a few questions about the Tarett Racing Camber Plate. I have purchased this as I want the ability for more adjustment up front for Camber. My only hesitation is the fact that when they are fitted, as you see in your picture, it seems like the bolts are way too short. I have heard reports of them failing from Jamie@Dundon Motorsports. have you heard the same thing at all? Because of this I am hesitant to put them on the car. Thoughts?
#50
As far as "failure", I would have Dundon clarify what failed. All monoball/bearings will develop play over time, but I've never heard of studs on any tarett strut mounts failing. I've had a pair on my 987 for 4 years that have been thoroughly abused, and no issues either, and it's not just because the studs are long enough to engage the locking threads on the nuts.
#51
In the 997.1 days, I was all for anything other than PASM. Today, I am wary of anything but PASM. So, bit props to you for taking new dampers on, but your early feedback (paraphrased: it's amazing that a setup with springs this stiff can ride this nice) suggests someone who knows what's up is involved. O
Cool to see an owner of one of these cars already optimizing it for track use here in the states.
#52
We probably have about 10 local GT4's all running these, I'm not sure what length studs are used, but never have had any issue to my knowledge. However, this pic is taken with the initial setup of the shorter studs, and I had Ira send me a set of 30mm studs. I questioned the same thing, and he said that their recent run of these seemed to have used 25mm studs instead of 30mm. It is easy to swap them out. These plates are rebuildable, bearings, studs, etc. Even with these shorter studs, there is plenty of thread engagement, so I wouldn't call it "way too short" but it is just under the locking thread. We've paint marked it and will watch them, and I'll just install the longer studs the next time I need to get in there, or if we see any movement.
#53
Call it $25K. The wheels are the biggest waste, you could reduce it by 8K just on those alone. They look just like my Apex EC7 wheels for my E92, which are $1100/set. Makes me sick thinking about it, thanks for that! LOL.
The car doesn't "need" any of them though, it's just about perfect right out of the box. I just can't leave any car alone. It's a disease.
I finally got a quote for the TTX, called öhlins in sweden, man those are 8100Euro. Puh, are they really worth it?? On track they just must be like a totally different experience??
#54
Either, IMO, will be a legitimate upgrade to the stock PASM for those who don't mind turning a few ***** from time to time. And if you are a 6MT guy like I am, but want an "RS" type of suspension, this is honestly the best option for you.
While upgrading springs on the stock shocks is a legitmate upgrade, at these types of spring rates, ~double the stock ones, I feel like you are compromising the damper at that point, and they aren't really valved for something that high, and you'll still get that jarring "crashing" spring sensation.
Thanks for the response. I will ask Jamie what he was talking about for clarification, from my understanding he was talking about the lack of thread from the studs through the bolt failing. There are several cars in our area running them as well and heavens heard that yet. Congrats on the build! car looks amazing with great parts.
#55
Really nice build
Good to see that someone is trying aggressive spec camber on the 991 gt3 it s very near what manthey racing did on my gt3 and it made a really god change.
I understand that the camber on the 991 gt3 behaves in a strange way as at first I also had the feel that the car was almost better with standard geometry than when I went to medium camber about -2.4 and -2.0... but when I went around -3.2 and -2.7 then the car was faster on track and still useable on the street
so probably you get a difference and an advantage on track compared to the standard geometry wich works well only if you go really agressive and drive aggressively on a tighter and curvy track.
Are your wheels 19"?
I would like to see them fitted
I also tried many different suspensions but on different cars (proflex, intrax, penske, nitron, ohlins road and track, bilstein, sachs) but my gt3 is fitted with oem suspension as I find it s really well tuned and would not want to spend money on some suspension only to find out they arent how I like etc.
I had that feeling with some intrax on a scuderia they felt really really nice quality but were valved way too soft for my liking.
On a mini jcw I fitted the ohlins road and track and I fell that in that application the fvd system would make it more bouncy on a bumpy road as if after a bump the rebound was letting the car come back up too fast (as probably intended to keep the wheel in contact) but at least on the mini that have got such short travel it didn t work well as soon as you were using it in agressive mode but I don t know about other cars.
I would be curious to see how those ohlins go on the gt3 and also how they would compare with the KW clubsport made for manthey racing did you also consider those?
More picture please
More picture please
#58
Basic Sponsor
Thanks for the support on the Essex/AP Racing discs, and I'm looking forward to seeing some fresh pics!
'09 Carrera 2S, '08 Boxster LE (orange), '91 Acura NSX, Tesla Model 3 Performance, Fiesta ST
Jeff Ritter
Mgr. High Performance Division, Essex Parts Services
Essex Designed AP Racing Radi-CAL Competition Brake Kits & 2-piece J Hook Discs
Ferodo Racing Brake Pads
Spiegler Stainless Steel Brake Lines
704-824-6030
jeff.ritter@essexparts.com
Jeff Ritter
704-824-6030
