torque vectoring
torque vectoring
how does the torque vectoring work on porsche? is it brake only system and does that wear out rear pads? can ptv be turned on and off with a dash button? how important is it to have for an advanced hpde driver?
thanks
thanks
Maybe trail braking will cause the PTV system to activate less frequently - not sure...
And on other models, skipping the PTV means skipping the limited slip differential (something you want, unless getting an aftermarket LSD)
is the lsd something that will overheat and cause problems?
i had nothing but trouble w lsd on my 997 gt3.
i will not be pushing macan hard on track by any means. i use lotus for track and will only take macan if bad weather, family coming w me, etc. 2-3 times/yr at most. im experienced instructor and will only drive it at mild/moderate level
Since you live in NY, the LSD will really help snow performance too (not just traction under power, but PTV would be great for steering in snow/ice). Nothing worse than understeer in slippery conditions...
From: The way to hell is paved by good intentions “Wenn ich Purist höre...entsichere ich meinen Browning” "Myths are fuel for marketing (and nowadays for flippers too,,,)" time to time is not sufficient to be a saint, you must be also an Hero
isn t quicker calling each other by phone?
