991 GT3, GT3RS, GT2RS and 911R 2012-2019
Has any put the R diffuser on an RS
Old 09-09-2017, 01:22 AM
dark knight
dark knight's Avatar
Default Has any put the R diffuser on an RS
Im thinking of it since it looks like the Manthey has it
Old 09-09-2017, 05:48 AM
EST
EST's Avatar
Kobalt, ask him.
Old 09-09-2017, 06:23 AM
Kobalt
Kobalt's Avatar
Have it.
Not sure if it has any effect due to various circumstances.
Old 09-09-2017, 12:10 PM
dannyb
dannyb's Avatar
If you're talking about the underbody piece at the rear of the car, yes.
Old 09-09-2017, 03:23 PM
dark knight
was it easy to install? cost? change in ground clearance?
Old 09-09-2017, 04:01 PM
IPSA
IPSA's Avatar
Will probably create understeer w/o some front end adjustments.
Many are running " flat " wing setting already, i.e. we can add more DF with a simple wing fix but many have chosen not to.
On the Ring ( Manthey's back yard ) it may be a different story given the higher average speeds.
Old 09-09-2017, 04:41 PM
TRAKCAR
TRAKCAR's Avatar
Received 1,675 Likes on 777 Posts
I wonder if it's easy enough to install at the track. Only way to tell if it's faster.
Old 09-09-2017, 04:51 PM
IPSA
IPSA's Avatar
Apparently bolts in but may require a nip and tuck here or there.
Old 09-09-2017, 04:59 PM
RobbieRob
RobbieRob's Avatar
I think its 10 or 12 bolts if I remember correctly. Yes, very easy, would just have to jack the rear up a bit to get more room to wrench. Some long tube headers might need trimming, but stock exhaust will not require any work. Also, FYI, the PDK trans cooler area has to be cut out to get air to it, 911R has manual and different trans bottom cooling.
Old 09-09-2017, 05:12 PM
SanDiegoDavid
SanDiegoDavid's Avatar
I had it installed in June. I was worried about needing to add some dive planes up front to avoid understeer, but I haven't noted it. I have the wing, the sway bars and alignment favoring oversteer so the added rear downforce at higher speeds may be neutralized. I do like the look. Cost with install was $800. I have not noticed any ground clearance issues.
Old 09-09-2017, 05:29 PM
TRAKCAR
TRAKCAR's Avatar
I should pre-install it and swap at the track to evaluate.
Seems cheap enough to try.
Old 09-09-2017, 07:00 PM
dark knight
that looks totally cool, I wonder if you could paint the edge of fins blue or silver or if that would look too ricey
Old 09-09-2017, 08:19 PM
Drifting's Avatar
Received 1,340 Likes on 705 Posts
Do you just drive your RS to the track or C&C and back, or do you ever drive your RS around town, across rain gutters and speed bumps, etc?
If so it would surprise me if you didn't hit the diffuser fins on gutters and speed bumps.
Old 09-09-2017, 08:30 PM
SanDiegoDavid
Yes I have gone over some pretty big speed bumps, although I do go across diagonally. Same with exiting the parking garage at work and my condo, no contact with the fins, so far. As you can see there is clearance.
Old 09-09-2017, 10:03 PM
Drifting's Avatar
Do you Park your RS in a condo parking lot? Do you have a private space? Is there a security door to the condo parking area?
Quick Reply: Has any put the R diffuser on an RS
