Money2536's Sapphire Blue 991 GT3 Journal
#811
Hi Matt,
I am about to order the set of 3 wheel woolies. Does the 2" or 3" fit between the wheel barrel and rotors? Does the 2" fit between the caliper and wheel barrel? From your product listing description, sounded like these no longer fit the massive brake system. Wonder if you have an alternate recommendation for the barrels. Thanks.
#812
I finally stopped being lazy and ordered a Spanner Wrench set to lower the car. I'll let you know if they work. http://amzn.to/1SGFjVI
Is it a good idea to lower the car for cosmesis? The shock adjust are there for corner balancing not cosmetics.
#813
I'm sure it will be just fine. Many have already done it. Porsche is simply setting it up for suitability on the street. Most track alignments have the car lowered with more aggressive camber.
#814
Adjusting Ride Height w/ Factory Coilovers
Before:
After:
Front Lip Height:
The rake looks acceptable to me. I may see a little more leveling after header and side muffler delete. You may want to leave a little more room in the rear.
#819
Car looks great. When do you think you'll have the new headers on the car?
#823
#824
