991 GT3, GT3RS, GT2RS and 911R 2012-2019
Best Exhaust for a 991.2 GT3
Old 03-28-2018, 08:54 PM
  #346
CAlexio
CAlexio's Avatar
Received 1,976 Likes on 919 Posts
Originally Posted by Mvez
IMO, there is no con, except cost. This is why people do the Center bypass, because it's typically ~$350 vs ~$1750. But there is a reason that Cup cars don't have side mufflers......
It removes 40lbs from the rear of car
It retains full sport exhaust button function (for street cars)
It makes a little power
It creates better handling
It is a tad quieter than center muffler delete
It offsets the weight gain of a rollbar install
I prefer the TPC design over Fabspeed, because it has the flexible upper tubing, which is same as OE.
Anyone in California try this?.. where we have emissions inspections? Wouldn't this style of muffler delete cause issues when smogging the car.. whereas center delete does not?
Old 03-29-2018, 09:39 AM
  #347
RSA964993
RSA964993's Avatar
I keep hearing about disabling the valves when doing a bypass exhaust. I'm assuming these are the valves that keep the car quieter until it hits a certain RPM? Is this pretty common thing to do when getting the bypass exhaust done? Easily done? Any real downsides to doing it? I'm deciding on which bypass to get when I get my car but definitely interested in having "loud" exhaust at all times versus over a certain RPM. If anybody has done this I'd love to hear the results of this. Thanks.
Old 03-29-2018, 09:55 AM
  #348
Jimmy-D
Jimmy-D's Avatar
Received 1,465 Likes on 764 Posts
^ I have disconnected my valves. Best thing I have done. No more transition around 4000 rpm from open to shut(Back and forth). Also - it says in the Manual that you gain more torque with valves open- no reason to have them shut
Old 03-29-2018, 10:08 AM
  #349
RSA964993
RSA964993's Avatar
Just found the link where it's discussed. I skimmed thru it seeing if there is any downside which seems like there is not. I'm all for the noise. Why else would we be looking at the bypass exhaust to begin with?!
https://rennlist.com/forums/991-gt3-...***-valve.html
Old 03-29-2018, 06:18 PM
  #350
Mvez
Mvez's Avatar
Not to mention it decreases heat soak into the rear tires, which is probably the single biggest improvement the side muffler bypass offers. The increases air flow offers better cooling for the rear tires. Another reason Cup cars obviously don't run side mufflers.
Using the in-car performance software, TPC saw gain of ~7hp up top and ~7 lbs/ft tq in midrange, on the 991 GT3.
I personally like that the valves keep some civility if you want it. Long drives, or when you have somebody in the car, it's nice to be able to tone it down a bit if needed.
Old 03-29-2018, 06:38 PM
  #351
juanpablo046
juanpablo046's Avatar
If you remove the side mufflers in a 997 GT3 you end up without valves, I guess with 991 GT3 is the same.
Old 03-29-2018, 06:51 PM
  #352
JCL59
JCL59's Avatar
TPC side delete on order... agreed this is the best option. weight savings and heat reduction are biggest issue. Did not know this offers an addl 7hp... Mvez blessing too!
Old 03-29-2018, 08:11 PM
  #353
BBiAutosport
Basic Sponsor
BBiAutosport's Avatar
Here is a Chalk 991.2 GT3 with BMC Air Filter and BBi Center Section Exhaust Installed
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
Old 03-30-2018, 03:40 AM
  #354
hayn911gt3
hayn911gt3's Avatar
Very nice. How many hours are needed for the install?
Old 03-30-2018, 09:18 AM
  #355
Mvez
Mvez's Avatar
Completely incorrect. TPC has been offering valved side-muffler by-passes for years. It's the same part for 997 and 991.
Old 03-30-2018, 09:23 AM
  #356
GRPerformance
Platinum Dealership
GRPerformance's Avatar
Takes about 45 minutes really! Easy install, bumper removal is easy too, sounds daunting but it’s really well designed as you could imagine! We have these in stock!
Old 03-30-2018, 10:13 AM
  #357
GT971
GT971's Avatar
Any Data on HP/ tourqe gains with this setup ? Thanks
Old 03-30-2018, 06:19 PM
  #358
sechsgang
sechsgang's Avatar
Received 1,035 Likes on 486 Posts
I don't know if anyone is interested, but I'm going to take my Dundon race headers off of my 991.1 RS (about 1000 miles on them) and put on a side delete/mini muffler combination with my stock cats on to change things up. Never got a CEL with this setup and I'll definitely miss the power...but want to change to get a more high pitched sound and don't want to run LT catless headers and a mini muffler/bypass...that would be a little much for me. Anyone interested PM me! (headers would come off the car in a couple weeks depending on when my new exhaust gets in).
Old 04-02-2018, 12:32 PM
  #359
wurlie
wurlie's Avatar
Please do not write factually wrong statements. The above is simply incorrect.
While I appreciate many of the center muffler replacement variants, I am with Mvez and consider side muffler delete options by far the best solution, for all the reasons he listed above.
I have done that on 997 4.0 with a Cup system foregoing the valves, and installing the OEM Cup parts, living with the drone.
On the 911R I will install the valved TPC side delete pipes with Akrapovic central muffler (could have just as easily used the standard central muffler, but I suffer from vanity from time to time).
Best, w
Old 04-02-2018, 01:09 PM
  #360
BrntRubber
BrntRubber's Avatar
So what are you thinking of?
Quick Reply: Best Exhaust for a 991.2 GT3
