MISFIRE CODE GT3s
#31
Mine is a 2015, with 12000 kms done in almost a year. 12 track days (entirely auto-mode). No break in done. Took it to first track day after just 300 kms.
No engine issues so far. All four tires changed (after being worn out). Was advised to change front brake discs (steels) due to hairline cracks (but will wait a bit longer for that).
Interestingly porsche tech has advised that a new porsche bulletin requires spark plug change after one year (instead of two years per manual). Failure to change may impact warranty. This new requirement is engine related and only applicable to Gt3. My VIN is not part of ignition recall.
I know of at least a couple of cars in UAE with second engine change but don't have more details.
#32
To OP, few months ago, when a friend was having issues with his car, I looked a little into it and documented 6/7 cases reported in RL in various threads, here - https://rennlist.com/forums/991-gt3-...l#post12443927.
#33
Mine is a 2015, with 12000 kms done in almost a year. 12 track days (entirely auto-mode). No break in done. Took it to first track day after just 300 kms. No engine issues so far. All four tires changed (after being worn out). Was advised to change front brake discs (steels) due to hairline cracks (but will wait a bit longer for that). Interestingly porsche tech has advised that a new porsche bulletin requires spark plug change after one year (instead of two years per manual). Failure to change may impact warranty. This new requirement is engine related and only applicable to Gt3. My VIN is not part of ignition recall. I know of at least a couple of cars in UAE with second engine change but don't have more details.
#34
#35
Having owned a 997.1 GT3 for 6 years and put 26k miles on it. I noticed that my 2015 991 GT3 does
run with lower oil pressure at all revs above idle. My 991 has not been recalled, has run like a watch
for over 4k of hard road use and 1 track day. I always drive it in manual after it's warmed up. Rarely
rev it over 8,500, when i rev it to the limiter it doesn't feel as fast. The power curve confirms this, it
falls away beyond 8,500 and peak power is at 8,250. The fact the recall involves increasing oil pressure
in the mid range, does point to an oiling issue in the heads. The 991 is a big step on from the 997, and
after running the 2 for 5 months, i sold the 997 as the 991 puts a bigger grin on my face. It's a keeper,
mega machine and i hope PAG get to the bottom of the engine issues. They need to race it to find out
more on it's weaknesses if there are any. Great thread, keep it going boys.
#36
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 4,377 Likes
Mine is a 2015 car, got it in January of this year. Went with white, since that's the fastest color.
About 6K track miles and 10K road miles on the car.
Have changed fluids more often than recommended by Porsche, and am using Mobil 1. Have changed plugs once, have not changed coils.
Did break-in according to Porsche recommendations, except that I gradually increased max revs after 1000 miles, but didn't track the car until about 1900 miles.
Track miles have been at instructor level. First half were mainly using PDK auto sport. Second half have mainly been using manual, and I usually short shift a bit for upshifts, but sometimes my downshifts are early, and the car will delay them until ready to accept, at which point it's probably close to 9K. So on average I may be easier on the engine for upshifts, PDK may be easier on the engine for downshifts, and I may be easier on the engine overall than PDK.
Road miles have been fairly gentle, mostly driving to/from the track.
Had a code which didn't reduce engine power which was due to an air leak. The leak was never found, and the code never came back.
Had another code due to low fuel and had reduced power. Resulted in misfires. Car ran fine after restarting the car, and has run fine since then.
Had another code due to low oil and had reduced power. Added some oil, restarted the car, and it was fine.
Have not overfilled the oil to the point of getting more than the yellow caution, and had some oil taken out when that happened (didn't track the car that way).
Have been using the Cup 2 tires the whole time.
I would like my engine replacement under warranty when the car hits 47K miles, please.
12/5/15 Update: Started the car yesterday and there was big cloud of smoke, but it ran fine. Started it today, and it was idling rougher than usual, then eventually reduced power warning came on. Restarted the car, warning was gone, and no message in the message screen. Drove the car about a mile and seemed ok, but I'm starting to worry that all may not be well with the engine ...
Last edited by Manifold; 12-05-2015 at 04:59 PM. Reason: Confirmed that coils weren't changed.
#37
MY2015 Nov14 delivery with ~5,100 miles
Two track days in auto
Day to day driving in manual, keeping revs low until oil is ~180 degrees.
Break in per manual
Oil changed at 1,200 and 5k miles by dealership. First oil change, got an overfill message 3 weeks later...
Just had the annual done, my VIN was not in any engine related campaign.
It has never thrown a code.
Break in per manual
#38
I started one some time ago, but people didn't seem to believe there was a problem. My count of first hand knowledge failures is now at 5. I have heard from one RL member that PMNA is requiring customers to sign a gag agreement when they are given a new engine - I don't know how many have signed and therefore are not willing to post.
Here are the other threads....
https://rennlist.com/forums/991-gt3-...d-again-5.html - 15 engine failures reported in this thread, doesn't include any of the ones I know about first hand.
https://rennlist.com/forums/991-gt3-...-failures.html
https://rennlist.com/forums/991-gt3-...l#post12391028
https://rennlist.com/forums/991-gt3-...rol-fault.html
#39
Heads in the sand it appears. Same type of thing happened with the early E46 S54 engine. it took someone with a bug up their posterior to target BMWNA and dig in to get things fixed. It's almost every event I'm at now that a GT3 goes home sick. Cold weather maybe? Maybe it's just Texas? PCNA seems to have a pretty good muzzle on people.
#40
We only have maybe 8-9 first hand examples of replacement engine due to cylinder misfire codes).
Perhaps you be helpful and can mention to those plentiful broken GT3 owners you keep coming across to come and post their issues here so we can build up a database.
We have a pretty good track record f standing up for ourselves :-)
#41
Maybe failed thermostats as those can be cold weather dependent. Starting to see quite a few of those crop up.
#42
I've used my code reader to pull error codes more than a few times on 991gt cars at the track. And of a few different cars.
i'm aware of 1 car that is now on it's 3rd engine. the latter issue was misfires that turned out to be scored cam lobes (I think).
#43
Updated my history today to add a reduced power warning: https://rennlist.com/forums/991-gt3-...l#post12806616
#44
#45
I had rough idle with an 'OK to drive' warning which would not clear. The coolant temp stayed low. Replaced the thermostat and no issues since. Currently at 9000 miles with the 12 month service done yesterday. Delivered 12/5/14.
