Blown 987 Base Boxster engine
6,000 miles later as I was waiting on the line at the Jersey side of the George Washington Bridge, my engine started to make this tin can rattling noise. I pulled over and discovered that nothing was wrong, as I got back into my car and continue on I noticed that the noise continued and it was even louder. Furthermore, I discovered a patch of motor oil where I once was. I got out to investigate and that's when the entire engine dumped it's motor oil on the side of the road. It doesn't look like it was leaking from the bottom rather it was the top. It was dark so it was pretty hard to determine anything.
Prior to my engine blowing up the oil level was fine as was my engine temperature. There was no CEL light or any lights for that matter. Any suggestions on what may have happened to my engine? It's a 987 Base Boxster with about 33k miles. Like I said, it went through a tough 6,000 miles this past week. The car was part of the AKA Rally. Furthermore, the car went excess of 150mph at Bonneville Salt Flats, but that was over 3,000 miles ago....Any suggestions? before the dealership opens up on Monday? Would this be covered under warranty? and if not why wouldn't it be?
Anything would help as this is my second Porsche, so I'm not exactly an expert.
Captain Obvious
Super User
Super User
Why not just have a quick look and see where the oil leak is. Them maybe take some pics and post them. Its a lot easier to diagnose a problem when there is some reference to where the problem might be.
Nope I don't have any idea and as far as I know Porsche has never released any information when the latest style was introduced. Safest bet is to buy the latest one you can afford but to tell you the truth it really doesn't even matter. Its not that common. Even if it does happen, car goes into the shop for a few days and you get it back with a fresh new engine installed for free.
PTEC,
I think I remember that around the third week of May in 05 the newly designed seals were fitted for the new 987's. I got that from either this board or PPBB.
Not sure why I did not remember that in my first post but must be my age. Any work that is done in that area will warrant replacing with the new type seals. I had been looking at new and only lately been looking at a year or two older to take advantage of the depreciation. Given that, I was trying to figure what has changed since the 987's were introduced. Not easy to find...
Yes the rear main seal was updated sometime in mid 05. That information on when that was introduced is readily available if you find the bulletin for the new PTFE seals. However there is no information on when the new intermediate shaft was introduced. I tried looking in PET and it shows different part numbers for the shaft, the flange and the nut but strangely enough it doesn't give any details on when to order which one. Anyways if your engine has an old style rear main and it leaks, yes they will replace it with the updated style rear main but you're still going to have the old style intermediate shaft/flange and nut.
Originally Posted by Old Chuck
PTEC,
When was the intermediate shaft redesigned and do you know what they did?
Close to a 987 and looking at the 05 and 06. That would make it easier if I know one had the IS redesigned.
I've not come across anything that indicates Porsche has updated the intermediate shaft since this time for the 987 or Cayman or 997 engines.
Sincerely,
Macster.
Originally Posted by Macster
went to larger bearing, different chain drive (which results in the crankshaft being different too), sometime in MY 2002, so this was for the 968.
Sincerely,
Macster.
Sincerely,
Macster.
