Sport Chrono not so great at the track...
The Sport Chrono package in Sport mode is fun around town, but on the track the throttle looses quite a bit of finesse; slight throttle modulations become way too abrupt.
Seems these agressive throttle maps are only meant for the street. I had the same issue with the Sport mode in the E46 M3.
I definitely wouldn't buy it again.
The oddity is that in sport mode it puts the PSM into a less aggressive mode, which is nice for the first few times out on the track when getting to know the car. But then you hit the overly touchy throttle. Fortunately about the time the throttle starts to bug you, you are ready to go with the PSM completely off. So, for an experieced track junkie, it is of value for about one track day ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
The chronograph is totally useless unless you also have the PCM (Nav); with the latter you can get lap times which would be nice. But then I use a Race Tech DL1 for that![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Anyway, if you are a track junkie, the Sport Chrono Package is basically useless at best.
Porsche needs to let us order the car with nothng
all I want is a shell, motor + drivetrain..
I wont even mind delivery of it with steel wheels + hubcaps...
I believe that if you can wait a little bit, there will be a race version available reasonably soon; think Cayman Cup racecar
This is based on some rumors and a few bits of info that Porsche plans to either race the Cayman or provide race versions for other teams to race. No info on the timing.
Addict & Guru
Good info. However, even when turned "off" PSM lurks in the shadows ready to intervene if preset parameters are met. The SC sport mode raises the bar before PSM "off" intervention allowing the driver more control. That would seem to be desireable for track use. SC seems like a Catch 22 - if you want a less intrusive PSM, you get reduced throttle control. Is that correct?
GT3 player par excellence
if they release it, i will get one, divorce or not!
i wonder if i can reg a race car in washington or oregon, LOL.
i think cayman will be raced in grand am cup, my guess really. but i am not sure it will be a factory supplied race car like cup car. but if they do, it's gonna be HOT. of course i am expecting it be cheaper than GT3 cup cars.
I've never driven a hair-trigger throttle before, but I'm learning how to use it. I was somewhat disappointed after my first day a VIR, and part of that was not knowing how to use the quick throttle. A friend rode with me the first session the next day and it was a whole different, and positive, experience. Now I'm starting to like it, except on the road, where I prefer the standard throttle response. I still need to learn more about how to use the strange (to me anyway) gear ratios.
PSM may still be lurking when turned off, but I've read that it will only be activated when ABS is activated. Thus, it won't intervene to keep the car from spinning, or crashing for that matter.
"A friend rode with me the first session the next day and it was a whole different, and positive, experience."
So your friend gave you some tips on how to use the sensitive throttle?
tino
tino
Originally Posted by wushuhsu
Doesn't Sports Chrono also up the rev limiter? That might be useful for the track.
I am on the complete opposite ned of the specturn from you, pstoppani. I find the SC throttle response as a must at the track and I loved it with the Bimmer as well
It becomes so easy to modulate the throttle application mid corner, the response comes without any delay. I am not sure how one can drive with the regular throttle response as the reaction is significantly delayed and you have to think of timing the throttle application sometime before you actually need it. Granted it is just a fraction of a second, but the delay is there and as I squueze the throttle, because of the delay, I tend to give more gas than I actually need. It just ruins the whole experience IMHO.
tino: No, he gave no tips on using the quick throttle. I must have learned something on my own.
I think in Sport mode there is what Porsche called a "harder", rather than a raised, rev limiter. I'm not sure what that means. The quicker throttle response means that the revs increase quicker with pedal pressure, but they also decrease quicker when one lifts. It seemed to me that the quicker decrease in revs requires more precise timing for heel/toe downshifts; something I still have to work on, as mine were not as smooth as they were on my RSA because the revs stayed up a bit longer, thus giving me a somewhat wider window of opportunity to complete the shift while the revs are still up.
Would be interested to hear your comments after a while using the PSM and Sport Chrono package - perhaps your not used to said configuration but with use and some driving style differences you might like it better over time?
Just playing devils advocate
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
