Swap from 19 alloys to 18?
I'm considering going from 19 35 profile tyres to 18 35, to get lower gearing for my local mountain roads.
Have any of you tried this, if so, was it notable?
Tall gearing just has to be lived with...I would love lower gearing but not willing to put small tires on it. Besides it will mess with the handling.
jbx2 (01-26-2024)
Yes, that would result in an effectively lower final drive, whether you'd feel it or not is a different matter that only you can answer. I would note the the weight of the wheel/tire combo would likely be a bigger contributer to any performance difference.
Cheers,
Julian
Cheers,
Julian
The 19 set with their Pilot Sport is a keeper, having possibility chancing when ever I like.
What I understand is no one of you have tried 18 your 987.
Plenty of people use 18s but with the correct size tires.
You might want to ping the racing & drivers ed forum on this. Common use case for racers is optimizing tire circumference to improve final drive ratio.
Cheers,
Julian
Cheers,
Julian
The performance difference will likely be minimal compared to the awkward wheel gap.
https://tiresize.com/comparison/
