What did you do with your 987 today?
Old 07-09-2024, 02:55 AM
  #1606
Sawborg
Sawborg's Avatar
Upgraded to the 982 steering wheel.
The following 4 users liked this post by Sawborg:
fatoldandslow (07-10-2024), mspalacios (07-17-2024), sasilverbullet (07-09-2024), wail junkie (Yesterday)
Old 07-09-2024, 09:38 AM
  #1607
Matt(inMA)
Not in MA anymore
Matt(inMA)'s Avatar
What's that clamped on the wheel?
Old 07-09-2024, 11:09 AM
  #1608
Sawborg
Sawborg's Avatar
JBL Click.
Old 07-09-2024, 11:12 AM
  #1609
Sawborg
Sawborg's Avatar
Originally Posted by quickboxster
Sorry, that's the power steering rack. Seen from the drivers wheel well. "Announced" by wet undertrays. HP hose leaking at the fitting .
I know the feeling. I’ve had both hoses replaced. Not a cheap job.
Old 07-09-2024, 11:55 AM
  #1610
Zach L
Zach L's Avatar
@KrisA I love the 90's-period look! Overall car looks great with the R suspension. Are the wheels from Meisterwerk? I'm considering a custom multi-piece set up from them. What's the width and weight?
Old 07-09-2024, 03:18 PM
  #1611
Dave in Chicago
Dave in Chicago's Avatar
Originally Posted by nicetheory
Where do you get your torque specs? Can you share this with me for my 987.2 work?
I use the LN Engineering drain plug @ 37 lbs, filter housing @ 19 lbs, not sure where I got those specs…
Got the brake brake specs from a doc I had downloaded at some point. Section here:
Note that the caliper bolts are one-time use, I replace them if caliper has to be removed.
Hope this helps.
nicetheory (07-18-2024)
Old 07-10-2024, 09:36 AM
  #1612
KrisA
KrisA's Avatar
Wheels are from Augment Wheels. Width and offset are standard Boxster Spyder specs. They could be more aggressive, they still sit inboard of the fenders by about a cm, but I wanted the ability to use spacers between these and my stock 18" wheels. Weights, not 100% sure as I didn't weigh them pre tires, but they are 4.8lbs heavier than my stock 18" setup. I was hoping for less weight, but my main design consideration was looks not weight so here we are.
Old 07-18-2024, 09:43 AM
  #1613
ARC72
ARC72's Avatar
Just had the stock exhaust on my 2.9 replaced with Cayman R mufflers with the Carnewal mod and Fabspeed tips. First impressions are that it's just slightly louder at idle, but throatier under load and has a really nice howl at higher revs. No drone. I didn't want it too loud so I'm happy!
The following 2 users liked this post by ARC72:
Kattman (Yesterday), sasilverbullet (07-18-2024)
Old 07-18-2024, 09:09 PM
  #1614
nicetheory
nicetheory's Avatar
Replaced both original tweeters in the dash with genuine Porsche tweeters. They were blown. Part number 997.645.021.00. Quick job, but a little annoying. My soundstage is a lot better now!
Julian_KCMO (Yesterday)
Old Yesterday, 12:21 PM
  #1615
p993_95
p993_95's Avatar
Replaced gas cap and air intake vents
sasilverbullet (Yesterday)
Old Yesterday, 06:15 PM
  #1616
sasilverbullet
sasilverbullet's Avatar
I like the vents, can we see a side pic of the whole car?
Old Yesterday, 06:53 PM
  #1617
p993_95
p993_95's Avatar
Here’s a couple, I bought them locally from a private seller, fairly certain they’re the same you’ll find on eBay so you can look there for more detailed pics
Old Yesterday, 08:03 PM
  #1618
Glue Guy
Glue Guy's Avatar
I like them too. What about leaves and such? Is there anything stop them from making their way to the filter?
also, what color is the car? Hard to tell if it’s black or something else?
Old Yesterday, 08:26 PM
  #1619
p993_95
p993_95's Avatar
Color is macadamia metallic I installed them last weekend, I took it out for spin and drove fine. Then I realized, the oem plastic trim on the driver’s side is probably preventing additional air flow… so I went a step further and removed the plastic trim you see here. Is it dangerous to do so due to debris possibly getting to the air filter, maybe, won’t know until I put some miles on it and inspect. I’m thinking I may add an additional fine wire mesh to the snorkel for additional protection.
Old Today, 11:57 AM
  #1620
p993_95
p993_95's Avatar
Worth mentioning that I had on hand a new part 987-575-757-00 to replace the original because a couple of the tabs were broken. It was only $20 at pelican. But what I ended up doing is trim all the tabs on the original with a Dremel and install it back prior to putting on the carbon vents. It gives reinforcement to the area around the snorkel.
Quick Reply: What did you do with your 987 today?
