Anyone with a Numeric shifter on a 987?
#46
Numeric shifter & Cables in 2014 S
I installed the Numeric shifter and cables in my 2014 S.
The description that the shifting now feels "like a rifle bolt" is quite accurate.
Wish I had them in my 911 track car.
Barry Thompson
Bristol, CT
Barry Thompson
Bristol, CT
#48
How would you compare the numeric shifter + cable on the 981 to the stock, and to a direct mounted shifter (for e.g. in a miata)?
#49
Shifter cable change for A/T
Guys - have seen so many messages on the shifter cables snapping on the Boxster/Cayman, but most seem to be for manual transmission. Is this a problem w the Auto transmission as well ? I have a 2008 Boxster S 3.4L (the Special Edition 2) which has the auto transmission (Tiptronic).
#50
Not really a fair comparison since the Miata lever is directly attached to the transmission; it's by far the most direct setup.
The stock 981 shifter feel is really good and I never felt the need to upgrade. The stock 987 feel wasn't as good and given the cable snapping concerns, the Numeric cables solved 2 problems at once: eliminated risk of snapping while providing the rifle bolt action that's been mentioned before. But you can still tell it's a cable-operated system with a slight amount of slop. I suspect adding the Numeric shifter itself would take that out if that's what you're after.
#51
#52
#53
Yup, believe they were working on a 981 version too
#54
Motivated by the 10% discount on the numeric racing website, I bit the bullet and ordered the shifter for my 981 CS. Will share some pictures once it's here and installed.
EDIT 2020/12/28: Shipped already. Arriving on 12/30!
#55
Shifter Vibration while in first gear?
Installed both the cables and the shifter in my 987.1 boxster. Really feel the vibration in the shifter when in first gear. Especially after 2-3k RPM. All other gears seem to be vibration free. Anyone have experienced similar? I've only driven it twice since the install. Not sure if it's something that will go away or I messed it up somewhere or I have a bigger issue.
#56
I just had one installed on my 981 boxster ... professional install by Olsen Motorsports, and it is AWESOME!
Almost bailed on it based on some of the very few negative comments but I'm glad I didn't. Great, high quality product.
RandyL (07-23-2024)
#57
Negative comments on the shifter. That'd be odd. Other than it's expensive there's zero to complain about. Adjustable, super precise.
#58
My 987.2 had been updated with Porsche OEM shifter cables so I had only the Numeric short shifter kit installed. Works out since I didn't want the extra NVH from the Numeric cables. The previous owner had an invoice for $900 for the updated parts and $788 for labor, eesh.
The Numeric short shifter feels exponentially better than stock OEM. Stock OEM feels quite terrible, I can feel all the plastic flexing around, the slop, and notchiness in every gear especially when cold. My only other experience with manual was an S2000 so I knew it wouldn't be good but the Cayman's was acceptable at best. I had it set to the 2nd throw setting and it feels awesome and a huge difference in feel and experience from the get-go. I can sometimes still feel a little bit of notch going into 3rd. Planning on changing the transmission fluid and hopefully that'll make things more buttery, as it made a big difference in the S2000. I'll take it over the Honda's infamous 2nd gear grind any day. When the car is warmed up, it feels 9.9/10 good as I remember on the S2000, well oiled and as cliche as it may be, truly rifle bolt action like shifts. I would compare stock shifter to a nerf gun. It's a must change IMO.
#59
If you install the cables as per the directions and don't use the clamp, there is no extra noise transmitted.
I had changed my trans fluid and it really changed nothing, still ground in second sometimes, first was difficult to engage while moving.
Now there is no cable noise, it shifts just fine into second and first is available again. I used the middle position so its a bit shorter than stock but now its exactly like a gated shifter on a Ferrari. I'm going to experiment with the "long" position to see if that is better.
If you are used to using a "feel" kind of shifting, like for an MGB for example, where you can easily override the synchros if you move the lever too quickly, you will find that the total Numeric setup doesn't at all work or feel like that, it really does feel like a rifle mechanism with its precision and predictability. So far, with my limited driving with the new setup,(broke my collar bone cycling) you really don't feel the synchros.
#60
I’ll offer a Numeric negative
But. The cables aren’t ideal. They make the shift action too stiff, making shifts slower and more difficult. Doing it again I would instead have the new OEM cable mount installed (I struggled mightily just installing the new cables, I’d pay someone to do the new attachment) and use Porsche cables.
going full Numeric nets a slight improvement and peace of mind but it’s nothing like an S2000 or Miata.
