X73 suspension: PDK vs Manual?
1) Was it a dealership tech that did the installation or a highly experienced indy Porsche tech?
2) Are you 100% sure the parts were all correct for a complete X73 kit? IOW, where did you get the parts?
3) The car you are comparing to, are you sure it has no other mods, is a correct OEM X73 suspension installed correctly?
4) Where are you measuring? I assume both cars are 981 cars. If so, measure from the bottom edge of the fender open, over the top of the tire, down along the tire and wheel to the ground. Compare both cars measuring the same way. What is the difference?
5) It's possible to not let the struts settle all the way to their fully seated position and clamping them in place, thereby causing a higher than normal ride height. Back to question 1, was it a qualified tech? Some Porsche dealer techs may have never done a X73 retrofit. I had a Porsche dealer botch a PSE retro fit, had another dealer un-f**k it for me.
I just measured from the ground to the wheel arch. It's just a tick under 27" on the front right, and just a tick over 27" on the front left. Both rears are 27.75". The fronts from the center of the lugs to the wheel arch are both basically 14.25". All tire pressures are equal. I have 20" OEM wheels with OEM size Eagle F1 tires.
OK so a friend of mine, also with X73, just measured the same; 26.5" from the ground to the wheel arch on the fronts and 13.5" from the center of lugs to the wheel arch. Guess that says it all - I am basically .5" higher up...
Can anyone else with X73 post their measurements?
I can't see the part #'s on the car itself, would need to take into a shop to do that. But I do have the original invoice for the parts when I bought the car. The suspension purchased was part # 981-055-400-04. This looks like the correct #, but it does mention it as a "retrofit kit". Not sure if that' the same as the OEM X73 that would have been installed form the factory. The parts originally shipped from Germany.
For additional reference data (I got curious), here are the specs from my '14 Boxster S with factory equipped X73, 17,000 miles, new Continental Extreme Sports in OEM sizes on 19 inch OEM wheels.:
RF 26.75"
LF 26.75"
RR 27.75"
LR 27.75"
Front wheel centers to wheel arch were both 14"
RF 26.75"
LF 26.75"
RR 27.75"
LR 27.75"
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/1500x2000/img_20200402_104908_c61c1ba90ea4f742890ba6a0528481e338d6a67b.jpg)
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/1500x2000/img_20200402_104910_009c3e93d7b2e162332b58fddd629695062e06f5.jpg)
Here are some notes i took with a bunch of pics and part numbers from my x73 install:
https://rennlist.com/forums/987-981-...all-notes.html
My kit PN (Cayman S PDK) was 981-044-400-05
Well I confirmed the part # installed on the car is in fact the exact same part # that Suncoast Parts has for their X73 suspension kit. I guess it's a matter of figuring if that exact set-up is indeed on the car. I also have a tech at my local dealer looking into how there could be a ride height disparity. As soon as I get it on a lift I'll update.
Location: On a pygmy pony over by the dental floss bush
From the Porsche WSM for 981 cars, for X73 equipped cars:
Quick check: Distance from wing (lower edge) to centre of wheel: 364 +/-10 mm
The following values relate to the empty weight, i.e. full fuel tank/fluid reservoirs, vehicle with tools, but without driver or additional weights!
EDIT: The 364 mm dimension is for the front axle. The rear axle quick check dimension is 374 +/- 10 mm.
OP, your car is almost spot-on the middle of range, 14.33 inches (364mm / 25.4 mm/in). Notice the +/- 0.400" tolerance (+/- 10 mm).
For this height check, the WSM makes no distinction between PDK and manual cars.
After I did my X73 retrofit, it took about 2,000 miles and one track day to get the suspension "settled". By this I mean the suspension had settled in so much the wheel alignment done during the X73 install had change so much, the car was requiring very noticeable steering input to maintain straight ahead course on the highway. I had another wheel alignment done, and all related fasteners re-checked for proper torque by the same dealer who did the install. After that, I never had any noticeable alignment changes due to track use or thousands of miles of driving. The Porsche dealer and tech who did my installation are very experienced in suspension modifications.
Suncoast had a 981 Cayman PDK x73 kit in stock so I jumped on it since these kits seem to be very unobtainable lately. I do have a manual trans though. I spoke to a guy on the phone at Suncoast and he said they've never tried to fit a pdk kit on a 6mt. Presumably they don't want to be responsible for selling "technically" incorrect part #s. I've run into the same issue when inquiring about the smaller gt4/sport steering wheel fitment into the CS too. Anyway....
He mentioned different part # for the rear spring (As we know from the chart above, different spring rate by 2-3 n/mm) and that it was due to the heavier pdk trans. He said he believes the rear bar might be a different shape, too. But again, no commitment to fit between transmissions.
I'm going to roll with it for now, BUT did anyone here actually verify fitment between the pdk/6mt versions personally yet? If not, I guess I'll be the guinea pig and best case is that fitment is seamless. Worst case, I'll have a kit to sell to a pdk owner lol.
This thread now belongs in the 981 forum...
