Gents, I've tried everything and my spoiler won't deploy on my 15 CGTS.
LED on the spoiler button does not illuminate at all, completely dead, tried the following:
Replaced the spoiler fuse
Replaced the spoiler motor behind the bumper
Replaced the button/switch console
Any ideas? is there a relay for this thing? Cheers
Not enough information. When did it stop working? Was work done on the car immediately prior to the failure? If so, was the work done anywhere along the electrical path of the spoiler system?
Did you apply 12v to the new motor to verify it functioning?
If it were me, I would start with the electrical schematic and work backwards from the motor to find where you have power/signal loss or perhaps from the switch. With the schematic, you should be able to find some test points to check for continuity. If work was done involving pulling interior panels, I would look for an uncoupled connector.
Thanks for chiming in. No work done on the interior, I drive with the spoiler deployed 90% of the time. IIRC, every time I had started the car prior with it deployed, the switch light was illuminated. One random day I tried to retract it and it wouldn't budge, tried multiple times and nothing, at some point, the light on the switch went completely dark. It was then that I bought a used motor off eBay and swapped it in. After that didn't work, I bought a control panel from a dismantler in Lithuania, swapped it in, and still nothing.
I did not check for basic 12V functionality, I'll try that on the old one and report back, seeing as the replacement motor is installed in the car currently.
From: South Louisiana, Bonfire Capital of the World
Not sure what fuse you replaced, but the only fuse shown in the circuit drawings is for the power to the Center Console Button Module. It's in the Left Front Fuse Box, Row C #1, 15A. It powers some other important stuff so likely a non-issue.
There are no relays in the circuit. The spoiler Extend and Retract functions are controlled by the Rear Body Control Module. All wiring from the Spoiler Drive is routed to the rear BCM.
The CAN network handles comms between the Center Console Button Module and other associated modules that have inputs to the spoiler function.
Here's the text from the Porsche Service Manual regarding programming when replacing the switch module.
WM 962719 REMOVING AND INSTALLING SWITCH CONSOLE (ALL MODELS) >
PRELIMINARY WORK
If a new switch console has to be installed, the values/coding must be read out using PIWIS
Tester II 9818 before removing the "old" switch console. → 962755 REPLACING SWITCH
CONSOLE
Remove cover. → 681919 REMOVING AND INSTALLING CENTRE CONSOLE COVER -
section on "Preliminary work"
The as-delivered state of the switch console is modular. If it needs to be replaced, the body
must be fitted with the operating buttons in accordance with the vehicle equipment.
If operating buttons are added, removed or changed, the switch console must be
re-programmed using PIWIS Tester II 9818. → 962755 REPLACING SWITCH CONSOLE
