Space behind the glove box
I am trying to find a spot to stash the small control box of a Mr12Volt CarPlay system. Can anyone tell me if there is empty space behind the glove box? If so how much?
I don't have the system yet so I need to get back with that information. From pictures it looks to be about 8-10 inches long, 3-4 inches wide and maybe a 1-11/2 tall.
If you haven't replaced your cabin filters, interior and exterior, the interior one is behind the glove box. Removing the bottom cover held with three screws, use a quarter, can be a PIA. Once removed you can see what space is available. There are YouTubes on doing the filters.
Well as suggested I removed felt like panel under the glovebox and saw that there really isn't much room for my CarPlay control box. Looks like some a/c parts and the cabin filter box. Don't know why I didn't remember that from when I changed the filter.
I recently installed the Mr12Volt CarPlay system and ended up placing the unit below the steering wheel.
The installation video suggests simply sticking it there, and it seems sit there happily without moving, but I think i will also attach the wires and unit to be on the safe side.
I was thinking of gluing an L-shaped piece of plastic there with some holes along the edge that I can then strip the wires and unit to.
Did you install yours already?
[QUOTE=norfrode;18912992]
/QUOTE]
@ElCid86 @markjon
/QUOTE]
@ElCid86 @markjon
ElCid86 (07-25-2023)
