Help with 981 GT4 Overrev report
Hi, looking at buying a 2016 981 GT4. I have the below overrev report, can someone tell me if it looks good? The car has a Cobb dundon tune, unsure if that affects anything. Thanks.
Received 2,309 Likes
No it doesn't look good. You have over revs in range 4 and 5. Porsche wont CPO a car in those ranges for a reason. For range 5 for example, the car has 55 ignitions when the engine had a total of 488 operating hours on it. The engine only has 50 operating hours on it since the over rev. Mechanical over revs can bend valve stems which reduces power and efficiency and later may lead to catastrophic failure. The damage can take up to 200 engine operating hours to reveal itself. I wouldn't risk buying this car.
My understanding is that for turbos, the tune does impact and skew the over rev report. I don't quite understand it but there is a video explaining it somewhere. It may be the same with NA engines.
Location: On a pygmy pony over by the dental floss bush
Received 2,533 Likes
There’s something off with the DME report as there are more range 4 ignitions than ranges 2 or 3 which is impossible. The tune may explain it.
Not necessarily. Given that the range 2 - 5 events happened at the same time, it was probably part of the same downshift event. Clutch engaged below range 4, then revved to range 5, then engine wound back down through lower ranges. But to put in context, if there are (3) ignitions per revolution, and (130) revolutions (390 ignitions) per second at 7,800 RPM, the engine spent ~0.4 seconds in range 4 and 5 (158 ignitions). But there was probably a missed shift into range 2 prior.
Schwinn (04-16-2023)
It may be fine or not. It may take up to 200 hrs to show issue. I would feel comfortable once it gets past 100 hrs after the event personally. It’s a personal question on comfort, what is your ability to pay out of pocket if it need to be rebuilt? That should be factored in to a offer, is it a dealer or private party?
Agreed with others - the report isn't great but is worse because of the short time since the range 4/5 events. My car, for example, has range 5 and 6 events, but that was over 800 hours before I bought it, which is why it was deemed a non-issue.
I might suggest having the seller provide a "short" warranty for that, if you can negotiate yourself there... basically to buy yourself some covered "hours" on the engine. It may be a tough sell to win that argument, but it's worth a shot.
I'd be more concerned with the Range 1, (90) minutes before the report was run. "To me", someone was trying to "get it in, before they got rid of it". That said, if you can fund a new motor, or motor rebuild shortly after purchase, it shouldn't be a concern. Realistically, its probably "one bad shift". That said, again, what were the conditions when it happened? However if your bank accounts work like mine, I'd keep looking, or at least find one with CPO left.
Dirtygrid (04-16-2023)
