Known Issues with 981 Base PDK Cars?
I'm a 997 guy but the wife wants to trade in the 997.1 S for a Car she can drive that we keep at our vacation home in SF.
Looks like I can Sell my car add about $15k and get a decent 981 Base PDK car.
It's fun enough for me to rip through the hills and easy enough for her to drive around town.
What are somethings I should be aware of?
The following 6 users liked this post by Kitc2246:
DBWhite (04-03-2023),
Diamond Dave (04-03-2023),
ElCid86 (04-13-2023),
Hella-Buggin' (04-03-2023),
KBell (04-03-2023),
and 1 others liked this post.
If it's a Cayman, then Headliner Sag.
Plus all 981 need the cooling system support clamp on the water pump exit.
toma nova (05-16-2023)
Titanium5150 (04-03-2023)
So on the 981 engines the Water Pump exits to a thermoset molded plastic pipe. This molded pipe has a flange for 3 bolts to attach to an aluminum housing.
Due to the dissimilar material expansion rates, this joint will start to leak over time. It acts like a water pump leak, due to its location, yet its not. The failure rate for this joint was high enough for Porsche to design and produce a repair kit, consisting of an aluminum "C" Ring and 3 longer bolts to support the Thermoset plastic pipe flange. See picture below;
The kit installs in minutes with no need to disassemble anything other than removing the 3 original bolts, inserting the new support clamp and installing the new longer bolts.
Saves you from needlessly replacing a good water pump.
The following 3 users liked this post by 981KMAN:
Location: South Louisiana, Bonfire Capital of the World
Suncoast has the feed hose but not the bracket.
Porsche Part Numbers are:
- 9A1-106-338-00 Retaining Bar
- 9A7-008-129 -00 Outer Hexagon Round (QTY = 3)
The following 10 users liked this post by 981KMAN:
01010011 (04-14-2023),
CaymanCarver (04-05-2023),
KBell (04-05-2023),
Larson E. Rapp (04-15-2023),
and 5 others liked this post.
Here is an interesting Thread from Piston Heads on this part. Seems other 9A1 engines have a similar issue? Piston Heads 9A1-106-338-00
Should you do this preventative so you don’t have any leaks or wait until you have a leak. Seems like you should change water pump at some point. I am only at 35k on my 14 base PDK. So far no issues, knock on wood.
I would not change the water pump until it needs it, you may get 100K miles out of yours, so until its needed..... drive on!!
The following 5 users liked this post by 981KMAN:
Ernest72 (04-04-2023),
KBell (04-03-2023),
TMc993 (04-04-2023),
Viper pilot (04-03-2023)
Location: On a pygmy pony over by the dental floss bush
I think it is a factory part on current models, and since it costs less than $50 it might be a simple add when doing your next oil change or at the Serpentine Belt change.
