"Upgraded" Steering Feel?
Kancamagus (08-31-2024)
#348
anderson930 (08-31-2024)
#352
My Base was built in Feb 2015 and the GT3RS coding was available in PIWIS. It installed fine but I haven’t had chance to try it out properly and I doubt I’m experienced enough to tell the difference from the GT3 that was present previously. I’ve also added Power Steering Plus as my partner considered it a bit heavy.
Christy P (09-01-2024)
nhnguy12 (09-02-2024)
#356
Just did this on my 991.1S, thanks for the instructions. As others have mentioned the PIWIS 3 is a little different.
I did notice all the changes others have described, but I've only driven it about 30 miiles so far (some twisty roads, mostly freeway.) One odd thing I noticed was that pulling into my garage (which is underground in a condo with a downhill driveway) the steering at slow speed felt really heavy, much heavier than the rest of the drive. I'll have to pay attention the rest of this week to see if that was just a fluke or if the downward slope of the driveway is doing something weird in terms of putting more load on the front tires and increasing the steering weight.
Also 991.1S shows an error code on the dash after coding, but I saw there are instructions for getting rid of that error.
nhnguy12 (09-09-2024)
#357
I found a similar screen on in the manual coding for the EPS module, but mine actually shows 997 GT3 Strasse, not 991. Which I found really weird since the 997 had a hydraulic steering rack I believe?
#358
Another morning of canyon carving and coding cars.
Didn't get behind the wheel of this 991.1 GT3RS but @JanssenT let me use his 981 GTS to test out the GT3 vs GT3RS EPS software. The GT3RS setting provided significantly more assistance off-center. This resulted in less effort required on turn-in but it also meant I had a harder time feeling the grip load-up/unload across the front axle. For fast driving I strongly prefer the GT3 EPS setting but I can see how people might prefer the GT3RS setting for ease of use around town.
EDIT:
Short clip of some very serious and scientific testing of the GT3 EPS on my car.
The following 6 users liked this post by nhnguy12:
AdrGTS (09-23-2024),
anderson930 (09-22-2024),
awasb (09-23-2024),
Christy P (09-22-2024),
Ernest72 (09-23-2024),
and 1 others liked this post.
nhnguy12 (09-22-2024)
#360
I'm hoping to have that available on my 2016 Cayman S... if not, I'll try the GT3.
The following 2 users liked this post by rr_gts:
anderson930 (10-06-2024),
Christy P (10-07-2024)
