968 Forum 1992-1995
968 cylinder head refresh
Old 09-09-2018, 09:35 PM
sm
sm's Avatar
I finally got the head off today. Do the cam followers need to be retained in their specific bores? Also, how should they be cared for while the head is out for machining / refreshing work? Should the lifters be in a bucket of oil?
Old 09-10-2018, 05:01 PM
RajDatta
RajDatta's Avatar
Yes, they line bored so they must go back the exact same way. If you look closely, each can follower is stamped with a number. Just keep them away from dust. Always good to leave lifters submerged in engine oil.
Old 10-02-2018, 05:48 PM
sm
sm's Avatar
Do the stamped numbers indicate the bore they came out of?
Old 10-03-2018, 12:12 AM
will968
will968's Avatar
No, small caps start with one on the front left, facing the engine. There are also numbers stamped on the head close to the cap on the cover gasket surface. Make sure you get them all facing the right way - stamped side out on each side.
Old 10-03-2018, 12:20 AM
will968
will968's Avatar
Old 10-03-2018, 03:29 PM
RajDatta
RajDatta's Avatar
Do the stamped numbers indicate the block they came out of?
I meant head. the head has a matching stamp on it.
Old 10-05-2018, 12:05 PM
V2Rocket
Rainman
V2Rocket's Avatar
the lifters/cam followers do NOT need to stay in their original bores, machining-wise, but they should remain where they were to match up with a "mated wear surface" on the camshafts.
Quick Reply: 968 cylinder head refresh
