CS steering wheel
#47
Hey guys I have an issue with my CS steering wheel. When I turn it it makes a terrible grinding noise. I'm sure that it has to do with that airbag delete horn contact. I think its rubbing against the back of the steering wheel wrong, although the horn works. I just plugged it into that hole and then installed the wheel over top of it. Is that correct or am I missing a part? Like maybe that little spring with a contact on the end of it from the old wheel?
Also I am worried about taking the center horn cover off of the steering wheel. Last time I took it off it went flying across the garage and I was worried I broke the little plastic tabs that hold it on. Is there any way to gingerly take that off or do you just PULL?
#49
Registered User
Ok the edge of that brass horn adapter was rubbing on the edge of the brass ring on the wheel. I filed it down a little and added some electric grease and it's pretty quiet now.
