Speedometer Question???
I am just now getting my 968 on the road after buying it 7 or 8 months ago. It is my understanding from the gear ratios at 3000 rpms I should be doing around 75??? Is this correct? At 3000 my speedometer shows 67mph? My tach could be off?
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
if you're running a 25.65" tire you'll achieve 25.0mph/1000 rpm.
the vast majority of you run 25 inch tires, with 16" and 17" tire combos.
so you'll be quite a bit short of 75mph at 3000 rpm.
see post #160
https://rennlist.com/forums/968-foru...-968-a-11.html
see post #160
There are many free speedometer apps for iPhones that use GPS to calculate speed. I'd get one of those and see if it's your speedometer. If the speedo is off, then (shameless plug warning), build one of these:
http://members.rennlist.com/tom86951...r%20Page1.html
Team Owner
you're running a 25.3" tire w/ 822revs/mile
3000rpm = 74.03mph
like Tom says, your gps app will confirm this.
btw,
i'm making 75mph @ 2311rpm on my 285-35-18 Contisportcontact 3's running the 0.600 6th gear.
3000rpm = 74.03mph
btw,
