Muffler - is there a drain hole in the front?
Hello all - I haven't had the chance to inspect under my car, so I figure I'll ask here to see if someone knows.
On Saturday I put a new battery in my '95 SY cab, and then ran it for about 20 min to let the battery charge it for a bit. After pulling it back into the garage, I have a puddle of water under the muffler - under the lowest point by the front of the muffler, not the tip side.
It's been a very cold winter here in the NJ, and it hasn't been driven for quite a while (at least 6 weeks) - and I know that Dodges and Fords have a small drain hole at the front of the muffler to allow condensation and water to drain and not pool in the muffler.
Does anyone know if our mufflers have a similar drain hole? I know there is a hole at the shield at the front of the muffler, and that is what the water seems to be coming from - but is there a small hole at the front of the muffler as well?
Thanks for any help - I haven't been able to inspect it, and we're heading back into a cold snap and getting under the car in the garage is going to suck.
Raj - thank you for the offer, I just may take you up on it!
I'm talking about the inlet for the muffler itself, the back box, where the dual tubes are there is a shield with a hole in the bottom - I'm getting water through that hole, so I'm wondering if there's a small drain hole in the front of the muffler.
Thanks for looking! It looked to me like it may have been coming from the seam of the muffler, I wonder if that weld failed. Thank so much for checking, looks like I have more inspecting to do!
