The 968 is still a competitive platform
http://www.paragon-products.com/Koni...ni8742conv.htm
http://www.paragon-products.com/KONI.../koni_3012.htm
I'm sure others will chime in with other suggestions. Not saying the KW's are not a great product.
Cheers
Mikey
What's your thoughts on the ground Control rears. The price looks very tempting. http://www.ground-control-store.com/.../II=749/CA=221
Product SKU #944rearco
944/968 (Rear) Coilover Assembly (Pair)
regular price: $799.00
Our Price: $649.00 per Pair
Desired Spring Rate
(If unsure give brief description
of expected useage):
(max. 255 chars)
Quantity
Add to Cart: 944/968 (Rear) Coilover Assembly (Pair)
Desired Spring Rate
(max. 255 chars)
Quantity
I don't like the looks of those Ground Controls for several reasons. Grade 8 is the same as the factory rear shock bolts so that's not even a selling point; KW V3 came with 10.9. Also, the upper shock spacer looks half-assed and there's no external adjustment that I can see on these. I'm over the days of spending an hours to remove my rear shocks and springs to change damper settings on Koni's vs 10 seconds per side to change damper settings on the KW.
You don't need KW's for that, just get a set of Koni Yellows and go autocrossing. If your stock suspension isn't worn out then just use that.
Cheers
Mikey
Yeah - towing from Tampa was quite interesting! lol I got 8mpg, so basically I towed from gas station to gas station! We rented a garage and had a great time! Will definitely go back, probably next year! Need time to pay off my gas bill! lmao
Thanks guys, very helpful. What I'm after is the best riding (for daily driver purposes--lots of rail road tracks to cross in my area) option that'll still be ok (doesn't have to be fantastic) in the handling department for the odd autox event and track day (nothing serious or competitive). Anything in the ~$3k and under range works for my budget. My stock stuff is very soft/loose, I think the dampers are done (150k miles on what look like stock dampers).
