Distributor rotor alignment
I have noticed a very odd situation. Looks like the bottom most connector on the distributor cap is getting a grove formed from the rotor rubbing against it. I don't remember there being a way to align this. Just put the spacers and install the rotor. I just installed a new cap and rotor and heard arching sounds coming from the cap (brand new).
I took the cap off and noticed it having grooves on the bottom most connector (brand new again). Very odd. Has anyone ever experienced this? What was the fix?
Got a brand new unit and same rotor rubbing on the bottom most lead on the distributor. The reason the original cap does not make noise is because it already has a deep groove. All the other three leads look fine and have no grooves.
Took the distributor housing section out and the cam pulley and bolt are tight, so that can be ruled out.
Any other ideas?
Any other ideas?
Tama, the front is in decent shape but the rear could have seen better days. As you know, they are made of a material that is known to corrode (titanium?). I might have to take things apart to investigate further.
Can someone be kind enough and post pictures of their distributor cap electrodes. I get scoring on the bottom most electrode. The other 3 are perfect. Seems to be an alignment issue as suggested. The rotor sits on the cam sprocket, which is mounted to the rear cam sprocket cover and the distributor cap mounts to the front cam sprocket cover. The two seem to be out of alignment by a bit.
OkRider
Raj, the covers are magnesium. When the magnesium boss on our covers corrode in half, such as what happened to mine, it grows apart. Thus causing the covers to warp.
