front/rear calipers
You run the stock front caliper on the rear? You use no proportioning valve at all? I am thinking of adding a rear brake bias controller in the cockpit.
Yes, that is correct. Installed m030 on the fronts and took the stock fronts and placed them on the rear. Tried a pro portioning valve but put too much to the rears. The m030's and the fronts on the rear make a great package and with the proper pads I can get way deeper into the corners and out brake most others
I'll try that and see if it works any better. My dust covers on my rear calipers are cracking anyway and the fronts are in better shape.
