Soliciting engine re-assembly support
I've never like the idea of removing material to make the parts match, I see it as treating a symptom.
But I just got a copy of the 944 manual, and it points out that you should put a thin film of oil on the sealing lip of the rear main seal. I didn't see that in the 968 manual, so I neglected to do that. I think I'm going to loosen the cradle nuts - again - pull out the RMS, and apply a coat of oil to it. Since I have the engine so completely disassembled, I might as well make sure I do everything exactly right.
http://www.woodcraft.com/stores/store.aspx?id=328
or any real hardware store
and after reading further, never mind I see you resolved that issue.
If the RMS is already in, I would just move on.
Think about the application of oil to the outside of the seal. It would be to make assembly easier and reduce the potential of damage occurring during assembly. You already have it installed, and via the method that the manufacturer evolved to. Removing it and reinstalling will only add potential of damaging the outer sealing surface.
Yes, I will attempt to time the cams myself. With the engine out of the car on a stand, at least access won't be a problem! I know a guy in Georgia who has recently rebuilt his engine, and will lean heavily on him for help with timing the cams.
I have a few more questions, both surrounding the installation of the oil filter stand/oil/water heat exchanger (henceforth referred to as just the oil filter stand). There is a connector piece that is visible i the picture below, with an o-ring on it:
Attachment 606324
This piece is pressed into the block, and according the the manual, it has another o-ring where in goes into the block. How do I get this piece out to replace the inner o-ring? It seems to be pretty tight, and I don't want to damage the groove into which the outer o-ring goes. Is replacing the innner o-ring critical, or am I risking more than I might benefit by trying to wrestle this piece out? I have both o-rings.
The second question concerns the pressure relief valve. The picture in the manual and the PET shows two o-rings that go around the valve, at the two ends of the shaft. But, as you can see in the picture below, my relief valve has only one o-ring, near the very end of the valve:
Attachment 606331
In general, my valve just looks different from those in the pictures, and Sunset only sent me the one o-ring which fits on the end of the valve.
Thanks.
Raj
What do you mean by alignment of the OPRV? It's a cylindrical piece that screws into a thread - what is there to align? Not doubting you, just want to make sure I understand.
Also, do you have any thoughts on why my valve has a single o-ring, while the one in the PET and the manual shows two? Thanks.
Tool: http://www.paragon-products.com/Oil_...2-fslash-1.htm
My OPRV looks just like yours, with the single o-ring.
As far as the o-ring mystery, it appears that there are in fact two o-rings, one labeled "6" in the exploded diagram of the OPRV in the manual, which is the one I received and have replaced, and one labeled "5", which you can only see upon disassembling the OPRV. They have the same part number in the PET (999 707 144 40), so they must be exactly the same size. Unfortunately, I only received one from Sunset, so I'm stuck until I get a new one.
