Tie Rod End Removal
Tie Rod End Removal
I am replacing my engine and am removing the tie rods at the steering knuckle to drop the front crossmember and steering rack. Problem: The tie rod end is worn and the pin spins in the bearing with the impact wrench when I attempt to remove the nut.
How do I remove the worn tie rod end? I'd prefer not to remove the tie rod end from the steering rack unless it is required. Any ideas?
Thanks!
Thanks!
Bannana Shine
I HATE it when that happens.
I'm too lazy to go out and check my 968...did you check the ends of the pins to see whether they're made to fit a bit (usually a hex bit) to hold them in place while you loosen the nut with a wrench?
Also, did you soak the threads with PB Blaster before trying this?
I always mark and seperate them from the steering rack. I leave the ends mounted to the spindle. Taking them off will normally destroy the boots unless you use the right tool.
Any auto parts store should have a tie rod end removal tool for loaner.
Raj
Raj
Thanks!
Thanks!
Push up on the bottom of the pin and it should lock it in enough for an impact to remove it. You have to push up with some force, I usually lower my car (on lift) onto a 2x4 that pushes the pin up. Then use impact wrench.
