Problem with the alternator?!?!?
My 968 died on me right when I got off the freeway. Even with the jumper it wouldn't start, I put a brand new battery last month. So i just replaced a new battery but if i take the positive or negative off, the car wouldn't stay running. So is there a problem with the alternator, that it might be bad??
-Parm
-Parm
Removing your positive cable is the worst way to check if you regulator/alternator is working. The voltage spike could fry your ecu.
Take a voltmeter and see what are the readings when the car is running. Should show over 13.5 volts.
oh alright, that helps a lot. But the alternator seems bad so might have to buy a new one. Any idea which one I should I get?
thanks
thanks
