Euro vs US specs difference
Hi.
Is there something I can look for on a '92 968 cabrio witch tells me if it's an european or an US version?
Or are the two identical?
Thanks.
Paul
Thanks.
Paul
There are few more than whats in this document but list is almost complete:
http://members.rennlist.com/vilhuer/options.pdf
US model has ROW ZZZ style VIN stamped into body in engine bay near right hand side shock mounting point. Only difference in it is that US and ROW models have different VIN sequence. This means 13th digit is different. In '92 MY possibilities were:
Same kind of difference applies to practically all models made. Each market has its own sequences and 13th digit tells whats what. It alone is enough to tell US and ROW model apart regardless if rest of the VIN uses ZZZ or not.
Black rear bumber pieces etc outside body features are not totally reliable way to tell the difference. For example those rear bumber thing were used in some obscure ROW markets also. For example cars exported to Saudi Arabia might have had them from production line.
Code:
ROW coupe ...NS80nnnn ROW cabrio ...NS83nnnn US coupe ...NS82nnnn US cabrio ...NS84nnnn
Not really because both US & ROW (european) model come with left hand side steering wheel.The give away at first clance will be like mention (side repeater or what we call here markers) bumperettes you can't relied on it since lot of US owners do the euro signals conversion which elimate the front bumperettes.
as already mentioned, U.S. cars have front and rear bumperette's. Euro cars have side indicators. J-Spec models have different taillights. Also, the U.S. only had 2 models, Coupe or Cab. No Sport, no Club Sport, No Turbo S.
All U.S. Spec cars came with a drivers side airbag, not all Euro Spec models did. Early '92's did not have a drivers side airbag, Club Sports also didnt come with an Airbag.
Are you sure? I know PET doesn't list non cat version but both 928 GTS and 964 was available in some ROW markets like Saudi Arabia without cat as unleaded fuel was not available there at the time. Option for non cat setup was:
M150 Emissions systems removed for countries without unleaded fuel
Although, you could be right on the rare Saudi Arabian spec cars.
Any 968 or any other '92-95 Porsche which were used in Saudi Arabia and few other countries when it was new had to be non cat model. Lambda sensor would not last for long with leaded fuel. Only question is if factory did non cat versions or if stuff was changed by importer. Both 928 and 964 were done without at Zuffenhousen production line. There were for example 117 ROW 928 GTS made without cats. Besides Saudi Arabia they were sold in Arab Gulf states and in RHD format in New Zealand and South Africa.
