968 Forum 1992-1995
Proper Idle for a 968?
Old 01-23-2011, 12:59 AM
MacinTek
MacinTek's Avatar
Default Proper Idle for a 968?
My 944S3 idles around 1200rpm. It seems a bit high... what is the proper idle speed and how does one adjust it on a MAF car?
Old 01-23-2011, 03:18 AM
JDS968
Bannana Shine
JDS968's Avatar
Mine idles at 1000rpm cold, then drops down to a rather unsteady 800-850 as it warms up.
Your idle air control valve might be stuck.
Old 01-23-2011, 03:50 AM
Eric_Oz_S2
Eric_Oz_S2's Avatar
Or the tps may be faulty
Old 01-23-2011, 06:16 AM
FRporscheman
FRporscheman's Avatar
I've been told DMEs sometimes need "retraining" or something like that. I forget what it's actually called, but it needs a Hammer or Durametric, or something similar. Did your DME come from the same car as your engine? And did you rebuild the engine?
My idle is around 850rpm iirc, I haven't driven it in months.
Old 01-23-2011, 09:50 AM
ernie9468
ernie9468's Avatar
Mine on start up & after a hard run!!!!!
Old 01-23-2011, 10:32 AM
kwikt
kwikt's Avatar
1000-1100rpm when cold and 800-850rpm when warm.
Old 01-23-2011, 10:51 AM
ninefourfourt
ninefourfourt's Avatar
I think you are refering to reflashing, but that usually involves a computer download, not a hammer
Old 01-23-2011, 05:36 PM
FRporscheman
I meant the Bosch "Hammer", which is the special computer interface device they made for communicating with the Motronic DME.
Old 01-23-2011, 05:53 PM
JDS968
Bannana Shine
JDS968's Avatar
But not nearly as fun as this kind of Bosch hammer [drill].
Old 01-23-2011, 06:06 PM
MacinTek
MacinTek's Avatar
Okay... here's the deal..
1991 944S2 with a 944S2 manifold and a 968 head, DME, harness, MAF, TPS and idle stabilizer. Idle is steady, no difference from cold to warm... just stays at around 1200rpm. Vacuum lines are new and routed correctly.
Old 01-23-2011, 06:25 PM
968workaholic
968workaholic's Avatar
What's the vacuum at idle?
Old 01-23-2011, 06:37 PM
MacinTek
MacinTek's Avatar
I have no idea and no way to test it.
Old 01-23-2011, 07:24 PM
FRporscheman
You can get a vacuum pump tool for like $20 at harbor freight, if you want. Where is Fallbrook, near the bay area? I have tools you can use if you're nearby.
Old 01-23-2011, 07:32 PM
ninefourfourt
my bad
Old 01-23-2011, 09:03 PM
MacinTek
MacinTek's Avatar
Fallbrook is in North San Diego County. So, not as close to you as I used to be. ;/
Quick Reply: Proper Idle for a 968?
