968 Forum 1992-1995
Sponsored by: HBI Auto
Rebuilding a 968 engine
Old Aug 17, 2025 | 09:44 AM
  #76
Mikelly's Avatar
Mikelly
With help from those who have done it. That's the only answer I have right now. More when I have those answers. Also, slight tweak to the plan... I may just go ahead and buy the pistons/rods and leave the deck height on the head alone for now.
Old Oct 3, 2025 | 11:17 AM
  #77
Mikelly's Avatar
Mikelly
slight update... Molnar rods and Wossner pistons, Fitspatrick cams, 36# injectors procured. Head & crank go to the shop Monday. Block and other parts are either completely cleaned or being clean by Monday.
Progress...
Old Oct 3, 2025 | 11:20 AM
  #78
Mikelly's Avatar
Mikelly
We chose not to deck the head, removing volume from the chambers, So the geometry of the head stays the same. The cam profile changes are aggressive but not so much that we'll need to worry about anything beyond setting the exhaust cam up with proper degree specification from Pete's spec sheet. I'll need a new chip and we'll run upgraded injectors to help take advantage of the increased compression and the change in lift and duration on intake and exhaust cams.
Originally Posted by walfreyydo
How are you determining piston/valve clearance with the reground cam and head shave, factoring in variocam changes to valve timing?
I am curious because I am interested in a more aggressive cam but not sure what cam specs can be run with variocam (and haven't been able to find alot of information on this). Is there a maximum cam profile that is known to work and not cause interference or some further documentation or information you can share?
I have read folks like Michael Mount say that they disable variocam when going to a more aggressive cam (which basically converts the 968 head to an S2 head with larger intake valves). I think at that point it would probably be better to run a modified S2 head with 968 intake valves over the 968 head due to the simpler chain tensioner design. Ideally I would like to retain variocam but run a more aggressive cam, just not sure what will work.
Old Oct 3, 2025 | 11:56 AM
  #79
LTDzak's Avatar
LTDzak
Interesting build. So you are able to keep the Variocam functional? Can you check lift and duration (or just lift) on the cams?
I have only found one cam card for a regrind that implies that Variocam remains functional, the exhaust cam is limited to 268 degrees total duration.
On edit, maybe rethink resurfacing the head? The 968 engines are usually well below their advertised compression ratio.
Old Oct 3, 2025 | 05:25 PM
  #80
walfreyydo's Avatar
walfreyydo
Thanks for sharing. I am also interested on the specs of the cams you are running.
Old Oct 3, 2025 | 08:34 PM
  #81
Yogii's Avatar
Yogii
Sounds great! Will it run on 91 octane?
-Yogii
AKA 968 Novice
Old Oct 4, 2025 | 10:53 AM
  #82
Motosport's Avatar
Motosport
Progress...
How much weight will the wossner pistons save over the stock pistons? Its my impression that the stock 968 pistons are reasonably light and a fair bit less than S2 pistons.
Alex
Old Oct 5, 2025 | 09:56 AM
  #83
Mikelly's Avatar
Mikelly
Def. NOT taking material off the head since we went the Wossner piston route. I'd rather not post the specs on the cam since I'll be racing this car. Competitors and all that, ya know? I can tell you that total duration is below that 268 number you mention.
Old Oct 5, 2025 | 09:57 AM
  #84
Mikelly's Avatar
Mikelly
The reason to go with the wossner pistons is more to do with the increased compression. The stock pistons put compression closer to 10.2-10.3:1 and we want to get as close to 11:1 as possible. Still staying on 93 octane.
Alex
Old Oct 6, 2025 | 04:47 AM
  #85
Motosport's Avatar
Motosport
Thanks, and great information on the compression ratios of stock vs wossner pistons.. I am looking to rebuild an engine this winter and have already decided on using molnar rods, but perhaps I should consider replacing the pistons too to maintain the 11:1 compression ratio..
Alex
