968 Forum 1992-1995
Sponsored by: HBI Auto
shifter booth and shifter knob
Old Jul 7, 2010 | 02:44 PM
tek_121's Avatar
tek_121
Default shifter booth and shifter ****
Hi guys, I need to change those 2 things, **** and booth.
I was searching on the forum to see if I need to get the whole console out, or is there a trick to get the booth off with out removing the console.
and also, where can I buy a leather booth? Do I need to make it custom if I want to put an after market shift ****?
thanks in advance
Old Jul 7, 2010 | 02:49 PM
jeff968's Avatar
jeff968
The shifter boot and **** are usually one piece covered in leather but PCNA did offer wood shift *****. Many owners will do the **** with an aftermarket piece and the boot in leather. There are many on eBay.
Old Jul 7, 2010 | 03:03 PM
tek_121's Avatar
tek_121
thanks for the tip, but are they a direct fit?
I mean for the after market leather booth and shifter, or will I have to work it out?
Old Jul 7, 2010 | 04:09 PM
bombfactory's Avatar
bombfactory
I currently have a 997 **** and custom boot under construction at AGLA. I'll post pics as soon as I get it installed. Alan says it should be done by Friday. We'll see...
-Austin
Old Jul 11, 2010 | 08:09 PM
odurandina's Avatar
odurandina
Team Owner
From: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
i can help.... after hemming my 968 shift boot on to my 997 **** (perfect fit), i simply polished it with 303
protectant.
the important thing is to cut the stock shift boot off with a razor right at the base of the ****
so you have plenty of length to make the new hemline. https://rennlist.com/forums/968-foru...uld-to-it.html
File Type: jpg
File Type: jpg
