968 Forum 1992-1995
What 968 projects are you working on right now?
Old 03-03-2010 | 09:37 PM
JimV8's Avatar
JimV8
Team Owner
The short answer. The whole car. Im at the point of putting it all together though. I stripped, cleaned, (polished the banana arms) the rear suspension, and went with polybronze bushings in the swing arms and uniball on the banana arms. The TT has new bearings and the transaxle is all cleaned up and painted. The front and rear bumper covers are patched and get primered on the weekend if time permits. I want the suspension, tt and transaxle bolted up by the end of Sunday. probably another 20 to 30 hrs to go before it makes big noise.
Old 03-03-2010 | 10:11 PM
PorscheDude1's Avatar
PorscheDude1
On the Radar
Jim,
do you still neeed the body seals?
I have the complete set minus door handle and mirror gaskets.
Old 03-03-2010 | 11:48 PM
FRporscheman's Avatar
FRporscheman
Hah, I wish my projects were fun like yours. Right now I'm replacing the door handle because it broke while I was installing new gaskets. I never realized one could slip the big gasket on from the small side, d'oh.
My main project with the red one is getting it out on the market. My main project with the blue one is getting it cleaned up so I can take pics and put it on the market.
Old 03-04-2010 | 01:13 AM
Miles968's Avatar
Miles968
My Spring is coming soon to do list
Change oil, Coolent flush, Spark plugs, brake/clutch fluid change, and possible trans fluid. In the past I have kept the car in my garage, but this year I was offered space in a friends garage while they spent the winter in Florida. I am delaying starting the project until they they come home in a couple of weeks.
Old 03-04-2010 | 10:03 PM
JimV8's Avatar
JimV8
Team Owner
Originally Posted by PorscheDude1
Jim,
Yes I do. I found the part #'s, but haven't ordered yet. Door handles and mirrors are ok so if you would like to part with the set pm me.
Old 03-04-2010 | 11:07 PM
PorscheDude1
On the Radar
Thanks Jim!
Old 03-07-2010 | 05:48 PM
Richy_s's Avatar
Richy_s
M030 calipers / discs front
Rebuild / powder coat rear calipers
CS front springs
Service
Gearbox oil
Veloce wheels
oh and front wheel bearings
Rich
Just had the wheels refurbed.
Old 03-19-2010 | 02:08 AM
Radiologue's Avatar
Radiologue
Tear down and repaint!
Old 03-19-2010 | 04:12 AM
PorscheG96's Avatar
PorscheG96
That's what I'm talking about Radiologue!!!
I pretty much finished my list with autocross #1 two days away.
Lowered ride height 1/2"
Refinished wheels
New coolant hoses, coolant reservoir, brake fluid reservoir, brake & clutch fluid flush
Cleaned front suspension and wheel wells
Old 03-19-2010 | 04:43 AM
flwbyu's Avatar
flwbyu
Radiologue,
That is some great 968 ****!
Old 03-19-2010 | 01:26 PM
jeff968's Avatar
jeff968
What did you guys pay for wheel refinishing?
Old 03-19-2010 | 03:24 PM
PorscheG96's Avatar
PorscheG96
$125/wheel
Old 03-19-2010 | 04:05 PM
Damian in NJ's Avatar
Damian in NJ
Washing mine today, vacuum/Lexol the interior, quick detailers wax, dress rubber, all to have her look pretty for tomorrows Cars and Croissants meet.
Old 03-20-2010 | 08:33 PM
Radiologue's Avatar
Radiologue
Hope to have updates in the not too distant future. I would like to have the car back together to start some track driving by the end of the summer.
Old 03-22-2010 | 08:36 PM
JDS968's Avatar
JDS968
Bannana Shine
Okay, here's a new one that just popped up:
Intermittent ABS failure, together with intermittent soft brake pedal and long travel. I start the car and I have ABS (it definitely works, I've engaged it on purpose to test this), but while driving, the ABS light comes on and, of course, I then have no ABS (which I also confirmed). Also, as I'm driving, the pedal feels soft and has a lot of travel when I depress it the first time after not touching it for a while, however as soon as I release it, it feels normal, (very hard with little travel, and very easy to modulate). At that point, I can hold the pedal down very hard, and it does not lose any pressure, as I would expect with a failing master cylinder or a leak.
It was suggested to me that the ABS failure may be caused by a bad ABS speed sensor, which in turn could cause the ABS system to screw with the braking pressure, causing the weird pedal feel.
I'm really not sure about this, any ideas?
I also inspected the sensors visually. The front two sensors were pretty filthy with lots of metal shavings, apparently stuck on magnetically, which I cleaned off. However, all four sensors were very tight and did not appear to be damaged. This did not help.
I have photos, will post later :P
