M030 spindle and hub swap
Hello all,
Has anyone swapped their non-M030 spindles and hubs to M030 ones (and some big blacks) or can give me some insight what is involved?
Are new struts and springs required? Any other changes?
I know there are cheaper, equally effective other ways to go, but any thoughts?
Eric
Eric
Eric, the hubs and spindles are bolt ons. You don't need to modify anything except the brake dust shields. I just pull them away from the rotor since they tend to rub because of the different tie rod setup on M030 spindles.
You can reuse everything, struts etc. You might need to change the brake lines.
Raj
Raj
Yeah, the same SY 968 that keeps beating my Horizon Blue 968 at the PCA Palooza car show! lol Its a beauty and deserves the prize.
What Raj said altho if you are diving that far into it, I'd suggest at least considering upgrading/refreshing the struts, as you will already need to get the car aligned after the spindle swap. Also (and hopefully this goes without saying) please put in fresh wheel bearing races and wheel bearings!
Regards,
Regards,
Regards,
Regards,
I miss that SY coupe. It was so clean and my daughter's favorite. Well, I do have 1st dibs if it ever comes up .
Raj
Um, Raj... bad news for you. It *just* sold, about a month ago. Brian from Rennsport bought it from Leonard and Mel. He's obviously thrilled with it. Brian's a nice guy, you'd like him and I doubt you'd be sorry to see him have it.
Regards,
Regards,
