Cannot see anything wrong myself but here is the reply from a well respected garage in the UK.
Rich - you have been very observant and spotted a very important issue - but your tensioner is perfectly normal and has just reached its maximum extension at which point it stops moving. This is a dangerous situation as owners assume as it is an automatic tensioner that it will always do the job - which it does not. When the gear type sprockets on the crankshaft and camshaft (that the cam belt runs around) wear they get smaller in the middles and so even a new cam belt can sit too slack on them and the tensioner does not have enough movement to take up the tension (worn rollers and water pump pulley have a similar contributory effect). However the answer is simple if you know anyone with a lathe - you simply pull out (or knock out) the white plastic bung situated on the tensioner arm and replace it with one made to the same dimensions except perhaps 3-5 mm longer on the large diameter to make up the slack lost and enable the tensioner to work in its full range again. If you cannot get one made I could make one for you but at current hourly rates, material costs invoicing and postage - as a one off it would probably cost £50.00 + Vat - which I know is ridiculous for such a small part but we cannot be at work without recovering our costs and so this is inevitable I am afraid. Good luck,
Never heard that before. Sounds like a band-aid solution anyway. For that price, why not do it right and buy both pulleys. I don't buy it. Also, I have a hard time believing these parts could wear that deep.
It's easy to check. Just take measurements of both pieces. Some should be able to measure pieces to compare.
Raj
I put the idler pulley on last night which has tightened things up a bit and I think the belt is probably now at roundabout the right tension but the worry is as the belt stretches a little I will not have movement in the hydraulic tensioner to compensate.
One more question - my parts pdf is showing 2 idle rollers for the cam belt 1 for the balance belt - I have 1 for each I guess this is right?
To be honest if I had gone through the workshop manual process I might not even no I have a potential problem as with the belt on, idler fitted and tensioner on the belt "feels" about right.
Its the fact I know the tensioner is at the end of its travel that concerns me.
Just to be a pain some more if anyone happens to be looking at their belts I'd appreciate if they could measure the distance between the tensioner body and the tensioning arm.
Thanks for all your help guys this forum is great.
With this sort of tension system I usually pin the tensioner and install it, put a small prybar on the tensioning lever, then spin the engine over a couple times and recheck the marks before I pull the pin and release the tensioner spring.
Also there are places in the rotation where the belt is pretty slack on the side the tensioner pulls on, rotating the cam to pull on the tensioner when you release the spring might also help.
