Anybody going to Barber with PBOC in November?
Porsche 968 Turbo
Motor and Power
• 3.1 Liter stroker motor; 8 valve
• 490whp at 14lbs boost
• Dry sump system
• Kinesis center lock wheels
• Front and rear wheels are setup for center lock
Brakes & Suspension
• 996 Turbo brake rotors and calipers front and rear
• JRZ 3-way adjustable coil overs front & back w/ remote reservoir
• Custom built tubular A-arms, custom suspension front and rear
• Tilton master cylinder and brake pedal assembly
• Tilton clutch cylinder and clutch pedal assembly
• Carbon fiber cooling ducts mounted to calipers
• Adjustable caster / camber plates
• Stainless lines front and rear
Body & Chassis
• Nascar style chromemoly rollcage
• Custom fabricated steering column
• Halon Fire system in drivers area and engine compartment
• Fabricated aluminum wheel tubs, interior work, and rear firewall
• One off molded fiberglass Porsche 968 body
• JLS 4 corner air jack system with roof mounted air lance adapter
• Helmet and suit cooler
• Custom Aluminum diffuser
• Carbon rear wing with custom fab mounts
Other
• Six speed with short shifter; upgraded transaxle
• Lexan front and rear windows
• Front wiper was built from a 944 Turbo rear wiper set up
• Front and Rear custom tow hooks
• Longacre rear-view mirror
• Carbon fiber 944 dash
• 944 Sport mirrors
• Momo Apache steering wheel w/ quick release
The list goes on...
I've got some more pics with the body off. Will post in time.
Motor and Power
• Dry sump system
Brakes & Suspension
Body & Chassis
Other
• 944 Sport mirrors
The list goes on...
