MPH to KPH Conversion - possible?
I know that the 944 style speedometer can be converted to metric by swapping the odometer gear to the metric one and changing the faceplate.
BUT... is it possible to convert a 968 speedometer? (odometer drive system is different).
Anyone have experience with this?
I'm only guessing here, but doesn't the drive read the same speed regardless? If you switched a mph speedo for a kph speedo, wouldn't the differently calibrated dial face simply read the imperial speed? Does this make sense?
Its easy, you are over thinking. Just change that section of the cluster. As Stew said, they read the same, just the numbers are different. I had to do that to my car since its Canadian.
Raj
Raj
Jaak, I guessing you are referring to the odometer in that procedure. If so thanks, because though I've gone to KM large faces on the dials I still have to deal with the odometer recording in miles.
