968 Forum 1992-1995
What's your cabrio suspension set up?
Old 02-02-2008, 06:02 PM
RajDatta
RajDatta's Avatar
Luis, that is correct. BTW, in 968's there is no difference in castor blocks. They are all the same, be it M030 or non M030.
Looks like the setup Thom is talking about would require a different kind of castor block.
I guess atleast we know it would fit a turbo.
Raj
Old 02-02-2008, 06:54 PM
Luis de Prat
Luis de Prat's Avatar
OK, I updated to 968 castor blocks when I went to 17" wheels, so the only 2 doubts I have are whether the BK brace will clear the Turbo piping and engine protection pans.
Old 02-02-2008, 07:27 PM
RajDatta
RajDatta's Avatar
As far as pans are concerned, Porsche put the rear pans on the early cars but deleted it from 93 on. They did a lot of cost cutting on 968's. So, most 968's don't have the rear pan.
I am pretty sure it wont be an issue on turbo piping based on Thom's pictures. If it helps, someone here can purchase it for you and ship it as a "gift".
Raj
Old 02-02-2008, 07:41 PM
Luis de Prat
Hey, that might be interesting if it turns out it will fit!
Re the rear pan, I've done oil changes for 2 friends with 968s and both have the rear pan, so I had no idea it was deleted on the later cars. FWIW the 944S2 cab didn't have it from the factory, either but I'm reluctant to pull it off the Turbo since it's totally stock except the wheels.
On another note, I'm not sure whether adding the lower BK brace or similar together with a strut tower brace would make the ride too stiff? Steve seemed to suggest that it was?
Old 02-02-2008, 08:11 PM
luckett
luckett's Avatar
Location: San Francisco, CA Porsche: '92 968 Blk/Cashmere
Caster blocks are one of those items that changed over mid model run as they ran out of the old parts. My car was built in Oct. '91 and had the old style caster blocks. I've seen other early cars also with the early style mounted.
Old 02-02-2008, 10:03 PM
RajDatta
RajDatta's Avatar
Chris, you are 100% correct. Later cars, all came with the same type of castor blocks. 1992 cars are very unique in that sense. They come with some very unique parts, the coolant hardpipe that goes to the front of the head was also available in that yr as well.
Lots of different stuff.
Luis, I should have strut tower brace in soon and will report back.
Raj
Old 02-02-2008, 10:05 PM
RajDatta
RajDatta's Avatar
Originally Posted by Thom
Yes, the BK brace looks very nicely made, but I don't like how it's linked to the castor mounts - those brackets look undersized compared with the brace itself and give me the feeling they might bend.
The Cup brace is a thick bar similar to this one except it attaches to all four castor mount bolts - the bolts used are longer.
Thom, any idea when this part was built. Looks like someone might have a knock off design on those.
Raj
Old 02-03-2008, 10:02 AM
SpeedBump
Happily Amused
SpeedBump's Avatar
Agree 17 inch wheels are the way to go, my 18s are just a stop gap until I find a set of 17s I like.
Old 02-03-2008, 10:10 AM
RajDatta
RajDatta's Avatar
Originally Posted by SpeedBump
Agree 17 inch wheels are the wya to go, my 18s are just a stop gap until I find a set of 17s I like.
+1
I plan to move back to 17's eventually. I will move the lightweights to the turbo for normal use and save the Speedlines for special occasions. 18's and cab are a bad mix.
Its a shame because our choices are very limited on wheels and tires. Looks like most manufacturers are abandoning 17's.
Raj
Old 02-03-2008, 11:48 AM
Luis de Prat
+1
Raj
Not over here. They run the gamut. The ones disappearing are the 16s. Thank goodness for Continental.
Old 02-03-2008, 03:23 PM
SpeedBump
Happily Amused
SpeedBump's Avatar
As for the BK lower Brace- it does not work on the 968 with the Stahl header installed, I don't know if that has any relation to anything on your turbo cab since the 968s are the first water pumping PCar I've owned. I would say your first move should be the 968 M030 sways, it made a world of difference on my wife's cab, I thought the whole suspension needed to be replaced until we did that.
Old 02-03-2008, 03:29 PM
Luis de Prat
Mark, I appreciate your insight, and that of others who've responded. This is the kind of advice I was looking for. Thanks!
Old 02-03-2008, 03:47 PM
Thom
Thom's Avatar
Yes, it works with uniball mounts made by the company that makes the brace.
But as I said the Cup brace works with OE mounts when used with longer bolts.
Old 02-03-2008, 04:39 PM
RajDatta
RajDatta's Avatar
Thom, Is the Cup brace available anywhere?
Raj
Old 02-04-2008, 01:42 PM
Thom
Thom's Avatar
I don't know. I'm not even sure it was a Porsche part as the few ones I saw looked quite rough.
Quick Reply: What's your cabrio suspension set up?
