Engine ? - What goes here?
I have one last open hole in the block and can't find anything to go on it. What goes here, just aft of the lower oil filler hole?
http://968.2ward.com/index.php?ALBUM=bshaw
Thanks,
Thanks,
I thought the same thing when I was reassembling my engine. The fact that the machined hole doesn't lead anywhere makes it even more confusing. These blocks are used for 944 Turbos, aren't they? Is it an oil feed connection point for the turbo, or something like that? Perhaps it's machined to a point and then taken further if the block is to become a 944 Turbo. That's my guess, anyway.
Clayton
Clayton
Clayton, there are no oil fittings in that section for 944 turbo's either. Only fittings for oil feed are on the upper balance shaft housing, the oil pan return fitting and the driver side engine/turbo mount runs oil through it.
Good luck.
Raj
Good luck.
Raj
