968 Forum 1992-1995
Sponsored by: HBI Auto
dual hood latch setup
Old Jan 17, 2008 | 03:40 PM
Damian in NJ's Avatar
Damian in NJ
Didn't Nick in the UK use this rad?
Old Jan 17, 2008 | 03:49 PM
RajDatta's Avatar
RajDatta
Originally Posted by FRporscheman
I've seen pics of that 9m intercooler - it looks very nice but I imagine it isn't cheap.
I also want to avoid cutting anything. Isn't it necessary to cut an opening for the 951 intercooler?
You are correct on that. Both setups require cutting but the FMIC setup requires holes on the bottom of the crossmember compared to the factory setup where the cutting is made to the front, where the latch would normally be.
Raj
Old Jan 17, 2008 | 03:52 PM
kasturbo's Avatar
kasturbo
Is there any detailed underhood pics of your car out there to be found. Any chance you would email me some?
Old Jan 17, 2008 | 04:03 PM
RajDatta's Avatar
RajDatta
Kevin, I sent you a PM.
What you guys must also understand is that what I own is a replica and I try to match the factory setup as much as possible. If a 968 turbo is all you are after, you are not limited to doing things the way the factory did it.
A FMIC will always be more efficient compared to one within the engine compartment. You need to do whats best for you. Each one has its merits and shorcomings.
With FMIC, you should also make sure you get additional cooling for your radiator since you will be adding another device in front of it.
Raj
Old Jan 17, 2008 | 04:08 PM
kasturbo's Avatar
kasturbo
Raj, do you have a link to that HMR radiator? I tried looking for it the other day.
Old Jan 17, 2008 | 04:21 PM
Damian in NJ
http://www.heritagemotorcar.com/research/index.htm
Old Jan 17, 2008 | 04:28 PM
kasturbo's Avatar
kasturbo
Thanks Damian.
Old Jan 17, 2008 | 08:16 PM
FRporscheman's Avatar
FRporscheman
That makes sense - the engine bay is flooded with warm air. But what about with one of those turbo RS hood vents, that will allow air to flow straight in from the bumper, through the IC, and out the hood? I feel this would be just as thermally efficient as a FMIC, and since the pipes would be shorter than a FMIC it has the small advantage of slightly less lag, right? I'm assuming longer pipes create a greater volume for the turbo to pressurize.
I definitely don't want to cut holes but I will if I must. It's not like my car is rare (relative to other 968s), so a little hacking here or there wouldn't be sacrilege. Though if a factory-style setup could be used, with an intercooler that fits in the same area, but is slightly different in shape, so it doesn't interfere with the front hood latch, this would be ideal. Trick would be getting it to look stock for me here in CA.
Old Jan 17, 2008 | 08:49 PM
RajDatta's Avatar
RajDatta
You can buy the entire body kit from Fitzgerald racing in Australia. He sells the naca ducts, the bigger bumper opening, the intercooler cutout. Pretty much a turbo RS kit in fiberglass.
Like I said, it all depends what you are trying to achieve with your setup. There are a few ways to do it.
Raj
Old Jan 18, 2008 | 12:16 AM
FRporscheman
Thanks Raj - as with every other part of this project I guess I have lots of options!
