I'm not so sure you would see any real gains as you need some backpressure for the engine...that said, I know Rich Glickel has had great gains with his exhaust, although I'm not sure of his setup.
As you can see from my signature, I have a high flow cat along with a full Cargraphic exhaust. As I recall their TuV approved claims are around 12-15hp gain, with some extra savings coming from weight loss compared to stock. Other than TuV ratings for Cargraphic I don't think any systems sold in the US (RS, B&B, Fabspeed, Powerhaus) have independent dyno testing-although they all may show gains as well.
From: San Francisco, CA Porsche: '92 968 Blk/Cashmere
If you go with just a test pipe, you may lose some back pressure. This may hurt performance.
Pure speculation. The 968 stock exhaust does not have a shortage of back pressure behind the cat. Have you ever see the inside of the resonator or muffler?
If you open up the exhaust flow, you get a huge increase in throttle response, which is one of the characteristics of the 968 that I most dislike. Even if there is a slight power loss (I'm not saying there is), the gain in driveability is worth it.
You're probably better off deleting the resonator before the cat.
I'm definately not interested in loud, and if you guys don't think it chokes the car much, I'll just leave it all alone. The exhausts I am seeing are fairly pricey for a 12-15 hp gain.
Will focus energy on some snazzy suspenders instead.
The stock 968 exhaust definitely chokes the car, but the side effect of opening it up is usually more noise. There may be systems out there that allow better flow with the same noise, but there is also a lack of unbiased comparison tests of the available exhausts.
If you want your car to perform better get:
1) autocross/track time
2) good tires
3) good alignment to performance specs
3) good shocks
4) thicker sway bars
5) better brake pads
If you want to impress your friends get:
1) expensive stainless steel exhaust
2) expensive stainless steel headers
3) wheel bling
These are fantastic cars that don't really need much to perform well.
I would never do such a thing. I would totally unbolt it though, if there weren't so many cops and CHP around here. A disadvantage to living so near the only local freeway.
I want to take it off for Laguna Seca. Don't lots of people drive without mufflers? I know this won't give me much power... I just think it will sound cool on the track.
